Hello,
So my issue is that I have created a UD field that calculates out the Total Cost of a quote so that the information can be saved on the table but when I change costs in the quote the UD field does not update to the new cost unless I manually change the field (the field pulls the total cost the first time it does the process but all proceeding times I need to change the field to a different number for it to recalculate). Is there a method or data directive that I could write that would recognize every time something happens the Total Cost UD field recalculates to the new total cost.
A Post Processs BPM on Quote.Update should do the trick.
But you will have to recalc the total yourself. Unless there’s a QuoteHed field that already has it - and if there is, then why are you using a UD field to hold a copy of the value.
There is no field that holds the information there is a field that calculates the costs each time the quote is opened.
If your are only concerned about your UD field matching that field (QuoteHed.DocTotalQuote
- which is like you said, not a DB table field), you could make a customization that updates your UD field everytime that displayed field changes.
