I have a BAQ which is utilizing the Part Table to pull in required data and then a subquery using the PartTran table to pull in the last tran date.
I also need the last years total usage in the report. I tried a calculated field where Part tran date >= @today - 365 days then sum PartTran.TranQty, but I just get the last tran quantity and not the total for the year.
What would be a suggestion to try?
Any help is appreciated.
Carol
Add a second sub-query for the totals, with the date criteria on the PartTran in this 2nd sub-query.
Don’t forget that you’ll have to account for the sign, based on the TranType. For example, Normal PUR-STK and STK-MTL parttran records will have a positive qty. PUR-STK obviously increases QOH, while STK-MTL decreases it. Lots of posts on here that list the sign for each TranType.
Yay … that worked.
Thank you!!!
Anya,
Thanks for responding… I was able to get it to work with a 2nd Part Tran table.
Carol
