We recently upgraded to 11.2.300.10 and I have not been able to get automation studio running. I get a “Connection failed Timed out connecting to server” error when testing the connection. I have tried setting web service license on/off but still no luck, I have also tried re-creating the API key.
Not sure if something happened after the upgrade but I am also getting an errors from the Task Agent when I try to autoprint about invalid credentials and XL broadcast errors.
Nothing looks out of sort on the server side, unless I am missing something. Has anybody ran into any of these issues ? Just looking for any indication of cause
What binding are you using? Can you connect to your app server in the admin console? Is your task agent using the same credentials? Can you pull up kinetic using the browser vs. the client?
I have HTTP/HTTPS bindings (I did just see there is no binding information for those two), I can connect to the app server from the admin console, should the task agent be using the same credentials (it is not currently)
I dont have firewall access but I did send this workato link to them earlier, IP allowlists | Workato Docs. Do you happen to know if the rules have to be in/out or both and its 443?
