Maybe one thing that can make a diff
Epicor told me that when i create the relationship to Company i should set
the relationship type to "Out put"
Try it maybe this makes a diff.
On Wed, Jan 26, 2011 at 10:36 AM, cooner_55421 <cooner_55421@...>wrote:
> > So I linked the part table to the company table
> > based on the company field.
> That was the last thing I tried and still didn't get any data but...
> By that time I was sick of it and I quit pretty easily.
> Good to know you finally got it to work.
> I'll try it again now.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, effgroups@...
> wrote:
> > I spoke to epicor and they basically confirmed what you said.
> > So I linked the part table to the company table based on the company
> field.
> > I exported only 3 fields (company,partnum,prodcode) so the xml doesn't
> get too big.
> > Then in crystal I linked the part table to the tphse table and it worked
> fine.
> > The only drawback is it will export all parts.
> > In you need more help feel free to ask.
> > Ephraim Feldman
> > Programmer / Analyst
> > Axis Lighting
> > -----Original Message-----
> > From: "cooner_55421" <cooner_55421@...>
> > Sender: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> > Date: Fri, 21 Jan 2011 23:11:02
> > To: <vantage@yahoogroups.com <vantage%40yahoogroups.com>>
> > Reply-To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> > Subject: [Vantage] Re: Time Phase Mtl Requirements Report
> > Hi,
> > I worked with Epicor on this same report last week.
> > It only has the TPhase temp table and company table.
> > You can't link to a temp table like TPhase.
> > Tried linking part to company.
> > Never could get it to work.
> > Let me know if you do.
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Ephraim
> Feldman <effgroups@> wrote:
> > > Thanks Brian
> > > We are on version 9.04.507A and i had no problems adding tables in
> other
> > > reports just this report it happens.
> > > Wondering if this is a new problem introduced with the latest patch
> level
> > > Ephraim
> > > On Fri, Jan 21, 2011 at 11:26 AM, Brian Roberts <broberts@> wrote:
> > > > That sounds the same as my recent problem -- see the thread "Adding a
> > > > linked table in report data maintenance". Affected me in version
> > > > 9.05.600C and was fixed by an updated to 602A.
> > > > Brian.
> > > >________________________________
> > > > From: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> 40yahoogroups.com> [mailto:
> 40yahoogroups.com>] On Behalf
> > > > Of Ephraim Feldman
> > > > Sent: Thursday, January 20, 2011 4:50 PM
> > > > To: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> 40yahoogroups.com>
> > > > Subject: [Vantage] Time Phase Mtl Requirements Report
> > > > Hi All
> > > > Im facing a interesting problem
> > > > I try to pull more part info in the report so i want to include the
> Part
> > > > table in the RDD. i did it and when running the report and open it in
> > > > crystal the table is there but if i use it the report goes blank.
> > > > I looked in the xml file and the table definition is there but no
> part
> > > > records gets exported.
> > > > Can someone point me what the problem could be.
> > > > Ephraim
> > > > [Non-text portions of this message have been removed]
