The current transaction cannot be committed
Has anyone had experience of the below error -
System.Data.SqlClient.SqlException (0x80131904): The current transaction cannot be committed and cannot support operations that write to the log file. Roll back the transaction.
The statement has been terminated.
I have found posts when people are updating records and a text field contains invalid characters. But it does not seem to be the case in this instance. The issue started towards the end of last week and has occurred every morning since (even weekends when no users are on). Once the issue occurs, every user gets the error when they try and update a record in Kinetic. you can still retrieve records?
We have a seperate SQL server to application servers and the only way to resolve the issue is to reboot SQL and the App servers. If you just reboort the app servers or recycle the app pools, Kinetic will not start. You get an error - Ice.Api.Exceptions.UnknownRestException: The service is unavailable (HTTP status code 503) .
We have disabled 3rd party backup software on the SQL server incase some sort of db locking was happening, but still got the error this morning.
Anyone had a similar experiance of this issue.
Thanks Neil
How big is your log file and or disk space? Any chance you’re full and it cannot accept new entries?
If you weren’t updating/upgrading and the issue just started happening… this could be a possibility. Rebooting can clear temporary resource issues and get you going again, but it won’t fix an underlying issue if you’re running out of space.
It’s also possible you have a specific long-running transaction that’s preventing other “write” activities. So, rebooting would terminate that transaction and let others through. Perhaps its something that’s running every night and that’s why you see the issue in the morning… you reboot… and you’re fine until the next time that transaction occurs.
Any additional errors on the SQL Server Logs that may provide breadcrumbs to the underlying issue?
SQL log file is 250Gb, with almost 200Gb free disk space on drive. We saw some errors in the SQL logs re-backups, so have disabled the 3rd party software etc. Agree that it seems something that starts daily, but not finding what at the moment.
How frequently do you do log backups? What Recovery Model are you using?
Recovery full, we have recently implemented commvault for full backup and transaction log backups. Would need to get full details of frequency. As I said we have disabled this and are currently just doing a full backup in the evening.
Yeah, a full backup is good to capture the whole database, but it doesn’t affect the transaction log. The transaction log backup is what allows the SQL server to truncate the log.
Especially if you’re in Full Recovery, your transaction log is recording every transaction and it’ll continue to grow until you do a log backup that truncates it.
But… sounds like you were doing that via commvault prior to the issue popping up, so, may not be the underlying problem.
Unfortunately I’m not sure what else to check other than to monitor for nightly long-running transactions. Hopefully someone else may have some ideas.
ERROR: “The current transaction cannot be committed and does not support operations that write to the log file” during catalog release in Procurement Supplier Portal
To resolve this issue, check if the size for the database log files are limited and check the free disk space of the database server disks in general.
To check if the file size is limited, use Microsoft SQL Server Management Studio. Right click the affected database and check Properties - Files.
Did you check limits on your log size?
In any case maintaining such huge log does not do any good, find out how to truncate it.
It looks like we have found what the issue is. We found an Epicor SQL job called - CaptureLogCleanup.CaptureLogCleanup.
The job is trying to perform - delete from cdc.CaptureLog where DATEDIFF(dy, OccurredWhenUTC, getdate()) >= 2
When this job was stopped Epicor was able to work as normal. We have disabled it for now and speaking to Epicor.
cdc.pdf (216.0 KB)
Replying because we had this same issue but a totally different cause and solution.
Our issue was caused by invalid characters contained in the part description. They would appear in the application as a box with a X through it:
Any changes to the part would fail, even trying to remove the offending character. In order to fix the problem, we had to temporarily disable the Change Data Capture (CDC) protection for the part table before we could edit the record. That is accomplished by using “CDC Table Management” screen to disable protection on the table (Part, in our case). Just make sure you re-enable it when you are done.
I will add, we were able to locate other offending records with the following SQL query:
SELECT
    PartNum,
    PartDescription,
    -- Display where the bad character is hidden
    CASE WHEN PartDescription LIKE '%[' + CHAR(1)+'-'+CHAR(8)+CHAR(11)+CHAR(12)+CHAR(14)+'-'+CHAR(31)+']%' THEN 'Yes' ELSE 'No' END AS Bad_Char_In_Description,
    CASE WHEN PurComment      LIKE '%[' + CHAR(1)+'-'+CHAR(8)+CHAR(11)+CHAR(12)+CHAR(14)+'-'+CHAR(31)+']%' THEN 'Yes' ELSE 'No' END AS Bad_Char_In_PurComment
FROM Part
WHERE
    OR PurComment      LIKE '%[' + CHAR(1)+'-'+CHAR(8)+CHAR(11)+CHAR(12)+CHAR(14)+'-'+CHAR(31)+']%';
