I have 2 different forms that are having the same issue. The first is my customization of the Job Entry form. I have added a field that when a part is selected it gets data from a BAQ for the rev from a UD table. I can see via MessageBox the value is being returned and while the message box is open I can see it in the textbox. However, once I dismiss the message box the value is wiped out. In this case I am filling the field in during the AfterFieldChange event like this:
I have also tried something similar with the Job Adjustment form where I want to populate the Employee Number with the current user’s Employee ID (from session). I have tried in several events but none of them retain the value. It disappears like the one above. I also have tried updating the employee ID from a BPM but I can’t seem to find the right one. I was trying to set up a BPM off the user clicking the operation complete flag but I don’t get anything (I have put in message boxes to show when it is invoked and I don’t get any message).
Is there a particular event I should or should not be using? I am obviously missing something.
Thanks Andrew. My Job Entry form is now working as desired! However, I tried to implement the same thing in the Job Adjustment form (my customization) and while it fills in the fields it isn’t saving the name or number (or at least I don’t see it when I go back in to look at the record). Am I using the wrong fields or doing something else wrong? It does save the value of the operation complete checkbox.
Looks OK to me. I’m sure it is applying the values because it won’t let you complete the adjustment without assigning an Employee. I would check Job Tracker and look at the labor transactions to see if the records are there.
It appears that the Job Adjustment form works with a LaborView not the actual Labor Detail table. I tried adding a UD field to store the user name but I don’t see it as an available field for binding a text box to. How can I get my UD field into the view? Are these views updatable? It feels like they should be but I am not seeing any data being saved into the Employee Number (which was already available).
