Text-to-columns in BAQ
We have order line descriptions that contains all the info we need, but I’d like to split it up in different columns. Is there a way to split these up using a calculated field?
Here’s an example -
Part Num - Part Description
12312 - TeamName - 123PACK - 12 (12312)
How would I go by making some calculated fields so that at first it takes everything behind the first “-”, then the second field would be after the first “-”, then the third field would be after the second “-”, etc. ??
I can get a field to display anything before the first “-” by using the command:
SUBSTRING(OrderDtl.LineDesc, 0, CHARINDEX(‘-’, OrderDtl.LineDesc, 0))
But I can’t grab the info after the “-” and so on…
In the Operators section, Under Ranges, see Entry:
Mark W.
That does the trick… Now I think I should try to combine this with another command to get it to the way we need it.
Thanks Mark.
