Test Environment
I have a separate VM setup to put a test environment for the purpose of testing upgrades. I have set up the databases and am trying to set up the server instance in Epicor Admin Console. I am getting a few errors.
The Client deployment share error I’ve verified that the path is valid.
This how the deployment should be set. Are you a level lower?
Yes, we are a level lower. From what I have been reading I need to run the installer to capture the files it is looking for. Getting more disk space on the server in order to do that to see if that will fix the issue.
