Nancy,
I've seen this error numbers of times - each for a different reason. Bad Backup (you tried that), vantage.st file pointing to wrong place, Service name missing or incorrect, wrong directory in Procontrol/Progress Explorer. Admin Service not running, etc. Hard to tell what is specifically wrong without going through each element of the install.
Troy Funte
Troy Funte
----- Original Message -----
To: Vantage Onelist (E-mail)
Sent: Friday, November 16, 2001 3:41 PM
Subject: [Vantage] Test Database won't start
Hi everyone.
My Ver5 database on my test server won't start. I can connect, the DB will
start, then it will try initializing and after a while it will give the
message "Startup of database local host 20931: Epic50 timed out.
I have reinstalled Progress - (patch 26), Reinstalled Vantage (patch 331),
tried 2 different backup files (prorest) from the live server, and have
called support. No luck.
Has anyone had this problem?
Nancy Dunn
Winco Ind.
Yahoo! Groups Sponsor
