Terminal Server access to database using local acco unts
I can't believe my fingers were that far off .VTG = .MFG
Cliff Drumeller
Information Technology Manager
Mass Precision Sheetmetal
408 954-0200 ex 217
Sent: Monday, October 20, 2003 2:28 PM
Subject: RE: [Vantage] Terminal Server access to database using local
accounts
Interesting that everyone refers to this *.vtg file which I haven’t found
yet. We are just running TS, no Citrix. Where is the *.vtg file(s) located
… I cannot find it on either server.
Thank you,
Sue
Sent: Monday, October 20, 2003 1:43 PM
accounts
We have been running Citrix with Terminal Server since Vantage 3.
I definitely would (and have) install Progress locally on the Terminal
Server, as this reduces a lot of network traffic from the Terminal
server to the Vantage server.
Before Vantage 6, I set the “TempDirectory” equal to blank in the
*.vtg file, and used “net use v: \\servername\epicor
<file:///\\servername\epicor> /persistent:no” in the usrlogon.cmd file
on each Terminal Server. If the “TempDirectory” is set to blank in
the *.vtg file, then Vantage will create a temp directory in the
“Documents and Settings\username\temp” directory. With the
“persistent:no” option in the Vantage drive mapping, the drive is
re-created each time the user logs on.
However; there is a bug in the automatic creation of the temp directory
beginning with ver 6 of Vantage… If you set the “TempDirectory” to
blank, you can not print ANY Report Builder reports.
In fact, this is not just with Terminal Server, but even with a LAN
client, if you leave the TempDirectory blank, you cannot print Report
Builder Reports!
The only way around it was to have a drive-letter mapped work directory
for each user!!!
Britt Moelling
M&M Manufacturing
Sent: Thursday, October 16, 2003 8:53 AM
accounts
Sue,
You will need to modify your .vtg file to exclude the temporary folder
of C:
\vntg**** whatever version you are working on. Terminal server creates a
temporary folder for each user on C:\temp\username and all the Vantage
temporary files created go there. Refer to documentation posted on
Epicor’s
web support. If you have NT TS and Citrix, I would avoid installing the
complete version of Progress as suggested in the same Epicor’s
document.
Stick with the client installation first and if it works, leave it as
that.
Another issue I found is that for Vantage 6.0 installation, the same
folder
of \\server\epicor <file:///\\server\epicor> was used for both Vantage
4.0
and 6.0. I followed the rule that you do not share the same drive letter
for
each Vantage installation. I used M:\ for Vantage 4.0 and S:\ for
Vantage 6.
0. It seems that this was an issue in my TS. I had to recreate user
profiles
to solve this situation. Unsharing the drive M:\ was not good enough for
my
TS. Maybe, someone in the group could share whether they had the same
problem and what solution they have.
Currently, I have Vantage 5.1-Progress 9.1 C and Vantage 6.0-Progress 9.
1D
installed and working in my TS.
Mario Aguirre
Lakin General
Sent: Wednesday, October 15, 2003 5:32 PM
To: Vantage User Group
Subject: [Vantage] Terminal Server access to database using local
accounts
Do any of you use terminal server to access Vantage? If so, how do you
setup the users? We thought we needed to setup local users and log on
locally but naturally you don't have access to the network and thus lose
any connectivity to the database server. What am I missing here? Are you
supposed to access TS using your network account?
Sue
Yahoo! Groups Sponsor
< http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705>
0071
83:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autored
ir?c
amp=556&lineid=3614674∝=egroupweb&pos=HM>
< http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egrou
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egrou>
pmai
l/S=:HM/A=1524963/rand=351614764>
have
and
<http://groups.yahoo.com/group/vantage/files/.> <
<http://groups.yahoo.com/group/vantage/files/> >
< http://groups.yahoo.com/group/vantage/files/
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
007183:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/aut
oredir?camp=556&lineid=3614674∝=egroupweb&pos=HM>
pmail/S=:HM/A=1524963/rand=696849903>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=170500718
3:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?ca
mp=556
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=17050071
83:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/autoredir?c
amp=556&lineid=3614674∝=egroupweb&pos=HM> &lineid=3614674∝
=egroupweb&pos=HM>
http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail
/S=:HM/A=1524963/rand=988335467
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmai
l/S=:HM/A=1524963/rand=988335467> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
ADVERTISEMENT
<http://rd.yahoo.com/M=244522.3707890.4968055.1261774/D=egroupweb/S=17050071
83:HM/A=1595054/R=0/SIG=124ukap9t/*http://ashnin.com/clk/muryutaitakenattogy
o?YH=3707890&yhad=1595054> Click Here!
<http://us.adserver.yahoo.com/l?M=244522.3707890.4968055.1261774/D=egroupmai
l/S=:HM/A=1595054/rand=855401095>
Yes, we use it. My users are set up to have access as a ts user on that
server. On their TS session we map them to the drive. On the server we set
up the client. It works fine.
accounts
Sue
Mapping them to the drive wouldn't be a problem if the ts could see
the db server in "local" mode. Here's how we log in:
username
password
server name (not domain)
Once that is accomplished, whenever we try to open Vantage it says
we don't have access to the shared folder.
I guess I'm asking you to be more specific. I know we should know
this so this is very humbling for me to ask.
Sue
on that
server we set
> From: Susan Iverson [mailto:siverson@j...]
> accounts
you
on
thus lose
Are you
> Sue
must have
Builder and
Sue,
Make sure that the server you are trying to log into has user accounts
identical to the ones you are using on the terminal server:
TSUser: jdoe
TSPwd: asdf1234
VNTGServerUser: jdoe
VNTGServerUser: asdf1234
This SHOULD work... *holds breath* as long as what you say is true, i.e. the
terminal server AND the vantage server (the one with the shared folder) is
not in a NT Domain.
You could then place in each of these users startup folder a batch file with
something like:
net use v: \\VANTAGESERVERNAME\SHARENAME /persistent:no
Does that help?
Michael
Sent: Wednesday, October 15, 2003 5:45 PM
Subject: [Vantage] Re: Terminal Server access to database using local acco
unts
username
password
Sue
on that
server we set
> accounts
you
on
thus lose
Are you
> Sue
must have
Builder and
Sue,
You will need to modify your .vtg file to exclude the temporary folder of C:
temporary files created go there. Refer to documentation posted on Epicor’s
complete version of Progress as suggested in the same Epicor’s document.
Stick with the client installation first and if it works, leave it as that.
Another issue I found is that for Vantage 6.0 installation, the same folder
of \\server\epicor <file:///\\server\epicor> was used for both Vantage 4.0
and 6.0. I followed the rule that you do not share the same drive letter for
each Vantage installation. I used M:\ for Vantage 4.0 and S:\ for Vantage 6.
0. It seems that this was an issue in my TS. I had to recreate user profiles
to solve this situation. Unsharing the drive M:\ was not good enough for my
Currently, I have Vantage 5.1-Progress 9.1 C and Vantage 6.0-Progress 9.1D
Mario Aguirre
Lakin General
Subject: [Vantage] Terminal Server access to database using local accounts
Sue
<http://docs.yahoo.com/info/terms/> Terms of Service.
Susan
As of Version 6 they are no longer .Vat's but .Mug's. I'll bet you
can find a few of these... Wait till tech support sends you looking for you
.vat's sort like finding relative bearing grease.
Cliff Drumeller
408 954-0200 ex 217
accounts
Thank you,
Sue
accounts
Builder Reports!
for each user!!!
Britt Moelling
M&M Manufacturing
accounts
Sue,
of C:
Epicor’s
document.
that.
folder
4.0
for
Vantage 6.
profiles
my
1D
Mario Aguirre
Lakin General
accounts
Sue
0071
ir?c
pmai
have
and
Terms of Service.
mp=556
=egroupweb&pos=HM>
ADVERTISEMENT
