Taxes on Misc Charge
I am on Vantage 6.10.536. Have not had many taxable sales so not sure how to get this to work correctly. I can apply taxes at the appropriate rate for merchandise sales. However I often have miscellaneous charges applied to orders. Typically these are shipping charges which are not subject to sales tax. Despite the fact that the Shipping Miscellaneous charge master file is marked as "Tax Exempt" taxes are still applied to the entire amount of the invoice including the (miscellaneous) shipping charge. I cannot find a way eliminate that unless I use the manual tax calculation on the invoice. That seems to defeat the whole purpose of the master files. What's more, even if you change the Taxable amount manually, to eliminate the shipping charges, you still have to do the math manually to arrive at the correct tax to be applied to the invoice. That too has to be changed manually, even though the taxable amount has been reduced. Does anyone know of a better way to do this?
Stan
