We have a customer who requires a breakdown of taxes, GST & PST, so the customer is set up for GST and we add the PST so 2 separate taxes are listed on the Order under Releases>Tax for each line and Header>Tax.
When we made the Invoice only the GST is listed. What did we miss
PST may be configured not to show-up on AR/AP there are checkboxes for that or it may be configured to only show-up during a Partial/Full Payment, or it may only be configured for a specific Jurisdiction.
@hkeric.wci - Shouldn’t you bae able to have multiple taxes per line even without an specific CSF?
Or is our case different because we have multiple authorities (Oklahoma State tax: 4.5%, Pontotoc County sales tax: 0.88%, and Allen city sales tax: 3%). As opposed to multiple taxes for a single authority.
I am not sure, according to the KB Article from support “Invoice Taxes different than Order” it said to configure the Canada tab as the resolution.
So im not sure, I just went based off Epicor Support KB It stated only Invoice has issues.
Their company is located in Canada, nontheless they should install the CSF - they have several Canadian specific features missing and Company config fields etc.
I am guessing that someone had an issue similar, hence the kb stating "properly on invoice"
We use Avalara, but it works mostly by creating the things needed to add taxes to orders and invoices. When you enter an address that would require a tax that you’ve not used before, the Avalara module creates the Tax Type entries. Avalara doesn’t create Tax Jurisdictions. So all my Tax Types look like:
Is this the first time that having two taxes on the same invoice line is giving you problems?
We are looking to get the CSF Can file from support, will give an update after we’ve installed and tested it. Thanks
Though I’m kinda surprised this wasn’t part of our upgrade. Wonder why Epicor didn’t bring it up (we literally just did in upgrade from E9 to E10)
So you have two tax types of collection Invoicing, GST and PST, you also have a single Tax Liability that includes both of these taxes.
Is the correct tax liability specified at the Invoice Header? Do the products have some sort of product tax category exemption?
As a test also, create a new Tax Laibility and add only the PST Tax, manually create an invoice and select this liability, do you get PST taxes calculated?
