We will be using DMT to apply Tax Code changes for customers. Anyone knows if we can do sales tax recalculation for massive open sales orders (Avalara) after the Tax Code changes?
Thanks.
Thanks.
I am not sure about triggering this through DMT, but if you toggle the ready to calculate field the taxes should calculate. Try it manually and see if it works.
I am always careful using DMT with open orders, make sure you test this outside of your Prod environment.
Hello, I’m new in Epicor and I have some tax calculation problems.Can you be more specific about: toggle the ready to calculate field?.
Regards …
The sales order has a checkbox on the top of the screen, Ready to Process. Change the status of the field and save, then check the box and tax will recalculate.
Are you using Avalara or the built in Tax Engine?
