Hello Folks,
The task agent is getting stuck and it’s effecting in all processes. While looking into the Multicompany error logs, found below error:
5/18/2020 12:16:24 PM (Server:localhost PID:10364 DB:DBSQL1\EpicorAPP1 Task:100971) Multi-Company Process - Error: System.NullReferenceException: Object reference not set to an instance of an object.
at Erp.Internal.SI.MT.MTPartImpVal.RunMTPartImpVal(Int32 pIntQueID, List1& tt_EFValidation) in C:\_Releases\ERP\UD10.2.300.14\Source\Server\Internal\SI\MT\MTPartImpVal\MTPartImpVal.cs:line 162 5/18/2020 12:16:24 PM (Server:localhost PID:10364 DB:DBSQL1\EpicorAPP1 Task:100971) Multi-Company Process - Error: Stack Trace at Erp.Internal.SI.MT.MTPartImpVal.RunMTPartImpVal(Int32 pIntQueID, List
1& tt_EFValidation) in C:_Releases\ERP\UD10.2.300.14\Source\Server\Internal\SI\MT\MTPartImpVal\MTPartImpVal.cs:line 162
5/18/2020 12:16:27 PM (Server:localhost PID:10364 DB:DBSQL1\EpicorAPP1 Task:100971) Multi-Company Process - Stopping Multi-Company
As per the error, I believe either in some records null value is passing or some configuration level having the issue. I am not sure where to get this.
What could be the route cause, any incomings will help a lot.
Thanks in advance.
