Taking the 5.0 Plunge
Shirley
What was causing the problem?
Shirley Graver wrote:
> !!!GOT IT!!. I'm going to need to reinstall the client on the
> workstation.
> Once that was done RB reports work fine.
> Shirley
> Yahoo! Groups Sponsor
[Click Here to Find Software Faster]
> To access the Files Section of our Yahoo!Group for Report Builder and
> Crystal Reports and other 'goodies', please go to:
> http://groups.yahoo.com/group/vantage/files/. Note: You must have
> already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Britt Moelling
M&M Manufacturing Co.
Last weekend we moved into a new facility, and other that
some small issues, everything went very well, and we were
up and running Monday am. One advanatage of this new
building, is that it is connected to our main plant with
fiber - No More T1!!!!!!
Now, users are starting to complain that login time is
extremely slow, and so is printing forms like POs,
Order Acknowledgements, etc.
No configurations were changed on the Vantage server,
and the switches are not showing any error conditions, so
it's not our connection (Word, Excel, other apps work fine)
I'm not sure where to start looking. Any help would
be greatly appreciated. I'd like to be able to solve this one
before I leave for vacation if possible. Thanks.
Tim Care
Electro Chemical Finishing
Tim,
Other then changing to Fiber, has anything else changed. New PC's, hubs, or
software?
Nancy
Sent: Friday, March 30, 2001 8:44 AM
Subject: [Vantage] Diagnosing Login and Print Slowdown
Tim Care
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
No hardware changes. We did some IP Subnet changes
so our 2 buildings are on the same numbering scheme.
The switches we are using are HP 4000s, and were in
use before, we just connected them with Gigabit ethernet
adapters. Speed is great for everything else, just some
small Vantage issues.
Tim Care
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, March 30, 2001 10:38 AM
Subject: RE: [Vantage] Diagnosing Login and Print Slowdown
> Tim,
or
> software?
> Nancy
> From: Tim Care [mailto:ecfmis@...]
> Tim Care
already
I have seen a similar problem that occurred on a WINNT client. My Domain
Controllers are WINNT 4.0 SP5. I had a hard disk replaced on a client
machine and the vendor installed WINNT SP6a on it. Vantage was terribly slow
on this machine until I removed the SP and brought it to SP5. Now it is
fine. I do not know what OS you have but thought I would mention it.
Todd Hofert
Spartan Graphics, Inc.
(616)887-8243
Tim Care
Well Tim, I'm not an expert on network communications. Changing the IP
subnet, makes me wander about unnecessary routing that was needed
previously. Or maybe not everything was changed correctly. So the PC's are
having problems finding the Vantage server. Is Vantage on a server by its
self?
Nancy
Sent: Friday, March 30, 2001 11:47 AM
Subject: Re: [Vantage] Diagnosing Login and Print Slowdown
Tim Care
> Tim,
or
> software?
> Nancy
> Tim Care
already
I've watch all of the traffic here on the 5.0, the good, the bad, the ugly.
I've re-read all the bug lists, the problems, the issues. I've scoured the
EraNet. Performed two test installs going from 3.0 to 5.0, and gone to
orientation seminars. I've read the install manuals 20 times. I've got my
backups done, users warned. Disks ready. Licence codes current. I'm
pumped, I'm primed, I'm ready to do this. Co-workers are saying I've been
walking around for days mumbling "No Fear", "No, Fear".
Tomorrow we upgrade.
My god have mercy on my IT soul
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
Best of luck Shirley, and let us know..
RichardL
Sent: vendredi 30 mars 2001 14:51
Subject: [Vantage] Taking the 5.0 Plunge
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
We replaced the Switch to Router to T1 connection on each end
with Switch to Fiber to Switch. Went around and checked all
IP addresses, subnet masks, and gateway assignments for all of
the PCs that previously were accessing Vantage across the T1.
And we pulled the plug on the router that used to serve the remote
building.
But, we are experiencing the problem with some of the machines that
were not changed as well. (Used to be local to the Vantage server, and
not accessed over the T1). All Progress statistics look ok, buffer hits,
etc.,
Tim Care
Sent: Friday, March 30, 2001 2:23 PM
are
> self?
> Nancy
> Tim Care
> From: "Dunn, Nancy" <ndunn@...>
> > Tim,
hubs,
> or
> > software?
> > Nancy
> > Tim Care
> already
already
already
Shirley,
I don't know whether to call you Brave or Suicidal.
I'll think of you often this weekend as I try to orchestrate a change of
ISPs.
Steve Sanders
Delta Centrifugal Corp.
Sent: Friday, March 30, 2001 1:51 PM
ugly.
the
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Shirley,
Does the fact that so many of us are saying silent prayers for you make you
feel less confident ?
Your job doesn't depend on this does it ?
Todd Anderson
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
<http://rd.yahoo.com/M=170603.1361494.2950176.2/D=egroupmail/S=1700007183:N/
A=613934/?http://www.newaydirect.com> www.newaydirect.com
<http://us.adserver.yahoo.com/l?M=170603.1361494.2950176.2/D=egroupmail/S=17
00007183:N/A=613934/rand=276788915>
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
<http://docs.yahoo.com/info/terms/> Service.
Allow me to offer the following quote:
"Far better it is to dare mighty things, to win glorious triumphs, even
though checkered by failure, than to take rank with those poor spirits who
neither enjoy much nor suffer much, because they live in the gray twilight
that knows not victory or defeat" - Teddy Roosevelt
Good Luck
Sent: Friday, March 30, 2001 3:31 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Taking the 5.0 Plunge
Shirley,
Todd Anderson
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
You go girl !!!!
Terry L. Williams Chipsco, Inc. 9936 Liberty St. Ext. Meadville, PA
16335 814-333-6331 fax: 814-337-2548 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Friday, March 30, 2001 2:51 PM
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
www.newaydirect.com
Jeez ... aren't upgrades just supposed to be boring and tedious ?
Sent: Friday, March 30, 2001 2:41 PM
Good Luck
I don't really have any other suggestions. Is there anything different about
your Vantage server? I just went around to my PCs and disabled the Master
Browser on them to cut network traffic. Some of the older ones that had
Print & File Sharing set had the Master Browser set to Automatic.
Nancy
Sent: Friday, March 30, 2001 3:05 PM
building.
etc.,
Tim Care
Hi Folks,
VISUAL: Dr Frankenstien in his tower (maniacal screams) "!!! IT'S ALIVE,
IT'S ALIVE"
Install went fine, usual panic stricken users this morning, sweaty hands
from hand holding, but we are running. I've corrected several custom report
builder reports but they still won't run from the Vanatage menu. I get the
message (unable to open convmap file 'e:\epic50\progress\convmap.cp)
ERANET was not helpful. Has anyone ecountered this before when running
custom reports in 50
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Glad the install went smoothly, Shirley. Can't help you with the report error. Still on 3.00 (Bawk, Bawk, Bawk). <-- Chicken noises...
Troy Funte
Liberty Electronics
Sent: Monday, April 02, 2001 10:46 AM
Hi Folks,
IT'S ALIVE"
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Shirley
I got that EXACT error this morning on one of our users (V4). This
users has a laptop, and was getting Prowin32 errors several times a day,
so Friday I just removed Progress from his laptop, and set him up on our
Citrix server... but I forgot to remove the Vantage Icon. This morning
he went into Vantage using the old Icon (not thru Citrix) and he
actually got in, but when he tried to run a report he got your error.
I had him go in via the Citrix Icon, and everything works fine!
So, it seems to me it is a problem with your installation of
Progress.... did you un-install the Progress 9.0B first???
Britt Moelling
> Hi Folks,
> ALIVE,
> IT'S ALIVE"
> hands
> report
> get the
> running
> Shirley Graver
> (End User)
> Sys Admin
> Cleveland/Akron
Britt Moelling
I talked to tech support and they sent me the followig:
Summary: RB, unable to open convmap with custom report links
Book: Support Solutions
Page: 1229MPS
XA 5.00
Problem: Opening custom report links in Vantage generates error: unable to
open convmap
Resolution: Vantage 5.00 no longer uses the registry to connect to report
builder
1.) Open the report builder.vtg and edit the "other parameters" line it
should look like this, with reference to the proper mapped drive and server:
[Vantage Startup]
Executable=V:\Progress\bin\prorb32.exe
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\Vantage.ini
ParameterFile=V:\Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H mntech -S epic50
TempDirectory=C:\Vntg50
StartupProcedure=
OtherParameters=
Note: the 'OtherParameters=' line is blanked out
Apparently this causes no problem with the database engine because it uses
the registry so. You will also need to edit the progress\Bin\progress.ini
to reference the mapped drive path instead of the physical drive path. The
startup section should look something like this:
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DefaultFont=MS Sans Serif, size=8
DefaultFixedFont=Courier New, size=8
DLC=V:\progress
Use-3D-Size=Yes
PROBUILD=V:\progress\PROBUILD
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROBUILD\E
UCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
UseSourceEditor=yes
EditorConfigPath=V:\prowork\proedit
Where V is a mapped drive.
XA 5.00
Now I get the SQL data base shut down error. Im going to try and reinstall
Vantage on my workstation and see what that gets me.
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Sent: Monday, April 02, 2001 12:47 PM
Subject: Re: [Vantage] Taking the 5.0 Plunge
Shirley
Britt Moelling
> Hi Folks,
> ALIVE,
> IT'S ALIVE"
> hands
> report
> get the
> running
> Shirley Graver
> (End User)
> Sys Admin
> Cleveland/Akron
Britt Moelling
!!!GOT IT!!. I'm going to need to reinstall the client on the workstation.
Shirley
