Hello,
Is there a better way to link OrderMsc to InvcMisc tables?
I’ve tried this, which works in most cases: where OrderMsc_Row.OrderNum == OrderHed.OrderNum && OrderMsc_Row.SeqNum == ttInvcMisc_xRow.SeqNum/10
However, when an OrderMsc record is deleted from the middle of a set of Misc Charges, the OrderMsc_Row.SeqNum will stay with its original sequence
While when the Invoice is generated and my BPM fired, the ttInvcMisc_xRow.SeqNum will resort to a sequence with no gaps
Thus, my association fails.
I need a better solution.
Here is the entire code of the BPM:
Erp.Tables.OrderMsc OrderMsc = null;
Erp.Tables.InvcHead InvcHead = null;
Erp.Tables.InvcMisc InvcMisc = null;
var ttInvcMisc_xRow = (from ttInvcMisc_Row in ttInvcMisc where ttInvcMisc_Row.RowMod == IceRow.ROWSTATE_ADDED || ttInvcMisc_Row.RowMod == IceRow.ROWSTATE_UPDATED select ttInvcMisc_Row).FirstOrDefault();
if (ttInvcMisc_xRow != null)
InvcHead = (from InvcHead_Row in Db.InvcHead
where InvcHead_Row.Company == Session.CompanyID && InvcHead_Row.InvoiceNum == ttInvcMisc_xRow.InvoiceNum
select InvcHead_Row).FirstOrDefault();
if(InvcHead != null)
OrderHed = (from OrderHed_Row in Db.OrderHed
where OrderHed_Row.OrderNum == InvcHead.OrderNum
select OrderHed_Row).FirstOrDefault();
if (OrderHed != null)
OrderHed.Proposal_Num_c = ttInvcMisc_xRow.InvoiceNum.ToString();
OrderMsc = (from OrderMsc_Row in Db.OrderMsc
select OrderMsc_Row).FirstOrDefault();
if (OrderMsc != null)
ttInvcMisc_xRow.ExtDesc_c = OrderMsc.ExtDesc_c;
To pass the UD field info from Order Misc to Invc Misc
The end result is all that matters. I don’t care to keep this way, if I have to worry about a user deleting out a Charge from the middle of the list and this occasionally failing.
I see, yeah I can’t help right now with that. I guess what I want to ask is, can you break down the business process so we can all see what you need to have happen?
I was told that 30 characters was too limiting for the standard field. I don’t make the rules on that one.
When an Invoice is generated, the 1000 character UD of the Order Misc Charges needs to pass to the corresponding Invoice Misc Charges 1000 character UD field that matches that line.
Looks like OrderMsc.SeqNum is a Key field.
Does that mean Epicor would limit me from resetting/resorting the values after the delete function?
I don’t know if there would be secondary ramifications to messing with a Key field like that.
Maybe I force my own sequence and insert it into a never (in my company) used field like Rpt3InMiscAmt.
@estm8ben Making a lot of assumptions without the data behind this, but IF both sets are on the header as it seems and they are added to the invoice every time then you could process them after an update of something like calculate taxes. Something like below.
var currentSeq = 0;
foreach (var InvcMiscRow where it is my invoice)
where OrderMsc_Row.OrderNum == OrderHed.OrderNum && OrderMsc_Row.SeqNum > currentSeq
InvcMiscRow.ExtDesc_c = OrderMsc.ExtDesc_c;
currentSeq = OrderMsc_Row.SeqNum;
If there’s always a 1:1 relationship between OrderMsc and InvcMisc, could you just build a couple of arrays. You could have the sequence number in the array. So, your order array would have 5 elements with sequences 1, 2, 4, 5 and 6. Your invoice array would have 5 elements with sequences 1, 2, 3, 4, 5. Then, just match the corresponding elements in the arrays.
