Rowley150
(Mark Rowley)
September 12, 2018, 2:21pm
1
Epicor 9.05.701
Is there a table of BAQs in 9.05.701 that shows
BAQ ID
BAQ Description
Author (User ID of who wrote it)
If the BAQ is in use…(i.e used in a crystal report, or dashboard etc)
Many thanks in advance.
UPDATE: I think the table “Exports” holds some of it
ckrusen
(Calvin Krusen)
September 12, 2018, 2:33pm
2
QueryHdr has all but “in use” A join to BAQ reports and dashboards could tell that
ckrusen
(Calvin Krusen)
September 12, 2018, 2:35pm
3
DashBdBAQ for BAQs used by dashboards
BAQReport for BAQs used by … you guessed it! BAQ Reports
Rowley150
(Mark Rowley)
September 12, 2018, 2:38pm
4
Thank you Calvin,
The only table i don’t have is QueryHdr, …maybe thats an E10 table?
ckrusen
(Calvin Krusen)
September 12, 2018, 2:42pm
5
Maybe. I’m going off of E10 -which > 90% of tables are the same since V8.
Does E9 have the ability to show field details right in the form?
Shows:
this pane updates as different form controls are given focus
Rowley150
(Mark Rowley)
September 12, 2018, 2:44pm
6
Hi Calvin,
It does - the table for E9 appears to be “Exports”
ckrusen
(Calvin Krusen)
7
Another “trick” (albeit a painful one) is to export the Data Dictionary to a PDF. Then search for tables with the same field name (i.e. ‘QueryID’)
ckrusen
(Calvin Krusen)
September 12, 2018, 2:45pm
8
E10 has no table “Exports”
ckrusen
(Calvin Krusen)
September 12, 2018, 3:00pm
9
I have a PDF of the V8 Dictionary, and it uses “Exports” as well.
ExportID is referenced in the following tables:
BAQReport
Exports
MfgCube
PerfSet
QueryCalcF
QueryField
QueryLikeR
QueryRelat
QuerySortB
QueryTable
QueryWhere
Rowley150
(Mark Rowley)
September 12, 2018, 3:03pm
10
thank you, i’ll get back on this again in the morning.
ckrusen
(Calvin Krusen)
September 12, 2018, 3:10pm
11
But it currently is morning
Rowley150
(Mark Rowley)
September 12, 2018, 3:16pm
12
It is in the US!
Not in the UK!
