Table & field lookup
Hey
with the many tables and even more tables in Epicor, is there anything that lets us search by table or field name? for example:
look for table - type in your table, select what you’re looking for, click ion the table and see the field list
Look for field - type in your field, select what you’re looking for, click on the field and see what tables the field is in.
The first one is relatively easily done in BAQ entry or Field Security Maintenance. Just add your table and then review the field list.
The second, I generally use the technical description with field help turned on.
I know that’s not the “easy button” you were looking for, but that’s my typical approach.
What @dcamlin said… and there’s always the Data Dictionary Viewer.
You might find the schema .chm helpful: [ Download ] Epicor 10.2 & Kinetic .CHM Schema
