Any success so far?
If you'd like you can contact me offline to discuss it in more detail. I
have struggled with this issue for a while.
Mike Tonoyan / Natel Engr.
Direct line: 818-734-6511
mtonoyan@...
Of Karen Schoenung
Sent: Thursday, August 11, 2011 7:40 AM
Subject: RE: [Vantage] Re: TabIndex order - how does it work for groups?
Some good ideas...I left TabIndexes as is, set those not needed to
false...First group box works, then goes directly to OK button (not in a
group box) - not sure what tabindex to make the OK button...Then tabs
back to Mtl and then will tab to second group box as we need...
So, I think the OK button is the main issue...I may try to play with the
on leave option.
Behalf Of bw2868bond
Sent: Thursday, August 11, 2011 8:29 AM
Subject: [Vantage] Re: TabIndex order - how does it work for groups?
Don't know if this would work or not but make sure the group box is the
Tab Index in between the fields.... (and tab stop is false)
field TabIndex = 10
groupbox TabIndex = 11
field TabIndex = 12
Otherwise maybe get references to the 2 entry boxes and use the OnLeave
event of the first box to do .Focus() on the next....
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...>
wrote:
Mtl(+tab), then user will have to click in qty to continue with the
other scans.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf Of Mike Tonoyan
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Behalf
disclosure to/by any other person(s) is strictly prohibited. By
accepting this information, recipients confirm that they understand and
will comply with all applicable ITAR and EAR requirements.
______________________________________________________________________
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
mtonoyan@...
Of Karen Schoenung
on leave option.
field TabIndex = 10
field TabIndex = 12
wrote:
>able to get close so far...We scan job (+tab), moves to Mtl, scan
> Thanks Mike, yes that is the form we are working with too. We were
other scans.
><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> Sent: Wednesday, August 10, 2011 12:03 PM<mailto:vantage%40yahoogroups.com>
> Subject: RE: [Vantage] TabIndex order - how does it work for groups?it
> I don't think you can control the tab order when moving from one group
> box to another. I spent more than a week trying to get it right for
> "Issue Material" screen. I wanted to implement a barcode system for
> issuing material using barcoded Job Pick Lists. Tech support told me
> was not possible to control it, unless I created a new form.<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> mtonoyan@...<mailto:mtonoyan%40natelengr.com>
Behalf
> Of Karen Schoenung<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Sent: Wednesday, August 10, 2011 9:06 AM
> Subject: [Vantage] TabIndex order - how does it work for groups?first
> I am trying to change the tab order of a form and there are two group
> boxes on the form...The tab goes through the correct order in the
> group box, but then goes to the OK button instead of cycling throughthe
> second group box. I tried this by setting to Tab false for all buttonsand is intended only for the person(s) named. Any use, copying or
> and text boxes that I do not want to tab to. What is the key to get to
> the second group box before the OK button?
> TIA
> __________________________________________________________[Non-text portions of this message have been removed]
