System tablenames for storing customizations
Looking for which system tables would store what has been customized? The Solution Workbench identifies what forms have been modified, so I would suppose it must be able to query some tables to generated that.
Looking for a way to generate some queries to see what is different from Test to Production.
Use SQL statement, List all customized forms in database.
select * from ice.XXXDef where typecode=ā€˜customizationā€™
Ok, that gives me the list of Customizations but what about what is different actually different with the Customization?
I see there is another table called Ice.XXXChunk which has the form mod, but how would I decode the contents and compare the differences??
select Decode([Chunk]) from Ice.XXXChunk where typecode= ā€˜customizationā€™
When you export the mod forms using Customization Maintenance you can view the exported XML contents of the file using a text or XML editor. What is your end goal or objective?
I wanted to compare differences without having open and eye-ball every single customization between 2 environments. Anyway, I found an earlier post that allowed me to decode the ā€œ[Chunk]ā€ field using a custom assembly and making that into a SQL CLR function. I can now loop through all the customizations.
(Thanks Jose Gomez !)
I use Notepad ++ free text editor. You will need to install the compare plug in. You will need to be in local administrator mod when adding the compare plug in. http://www.technicaloverload.com/compare-two-files-using-notepad/
You will also need to export the your customized form using the customization maintenance screen and open the file using notepade++ to compare
Would you be willing to share your CLR function or how that was created? I would like to be able to do this all in SQL if possible as well.
Tanner
I would share the C# project code (which is pretty much just what Jose posted) and how to call it, but donā€™t want to get into the SQL security settings to make it workā€¦what a PITA.
No need to repost, I was just hoping it was a simple solution because Iā€™ve really wanted to modify screen customizations in SQL instead of jumping through hoops in the interface but found no simple way to do so. Thanks for responding!
