Does anyone know if there is a way to enable System Monitor popups by default? I went through config editor to see if there was any options there, but no luck.
.sysconfig file <userSettings>
section, <StartSystemMonitor value="False" bool="" />
should be changed to True
Hi Olga,
Thanks, but what i’m talking about is the options to have pop up balloon messages from System Monitor.
That’s a Personalization. Not sure you can default those values for every user and for new users.
This is nuts. Surely at least the popup on error should be checked by default.
