2 days in a row now the system agent has spawned multiple processes for 2 different schedules
it started 16 different MRP processes at 11:30 pm schedule and over 100 dynamic query exports at 8:00 pm schedule.
I have opened a support case but was wondering if anyone else has seen this behavior
We are seeing this same behavior in 2022.1 with a few of our processes that are scheduled to only run once daily in the system agent. Did you ever get to the bottom of this problem?
Thanks, we also have a case open with support. I will update this once we identify a root cause/solution/workaround if I haven’t heard from you first. We are testing on 2022.1.9.
I just started seeing this on Jan 25, 2023.
Two Daily schedules at 10PM and 11:45 PM - 5 and 6 days a week. They seem to spawn until midnight.
.Net errors at both times.
Kinetic 2022.1.16
We had this issue and reported it to support back in September 2022. The case was moved to problem PRB0256224 and was supposed to be fixed in the 2022.1.15 update. Not sure if it fixed it but we changed all of our tasks to UTC and don’t have the issue any longer.
2022.1.15 seemed to resolve the issue for us. Scott we were seeing the same issue, they would continuously spawn until midnight. Did you install the latest version of the task agent when you installed 2022.1.16?
Daniel
New everything. Task Agent Service 4.2.100.0.
I solved the problem by removing the Time Zone parameter on the two tasks that run in the late evening.
