System Agent Next Run
Does anyone know why the time on my schedules keep moving? I set the next run to a specific date and time and at some point the time keeps shifting an hour later. I don’t want to have to continue monitoring it. Any help is appreciated.
I had this issue to. It’s an issue with the timezone stuff they started adding. It’s fixed on 2022.2.6 and you have to make sure you install task agent from the patch package there are point releases of the task agent, but you have to manually install them from the supplements folder.
I was having a problem where scheduled tasks in the last hour of the day would run every 10 minutes until midnight. That was tops.
Good thing we are upgrading this weekend to 2022.2.8. I’ll revisit next week, thanks @jgiese.wci
You will probably need to reset them all one last time after the upgrade. Good luck
