We are on 10.1.600.8. We are noticing that our System Agent daily MRP schedule are running a day off. We only see this issue with schedules were schedule type = Daily
We have this particular schedule set to run Monday - Thursday. It actually runs Sunday - Thursday.
We have used this same setup when in 9.05 for years with no issue. Anyone know why? It seems quite silly that I should need to pick Sunday - Wednesday in the UI to have the process run Monday - Thursday.
Any other schedule types seems to be ok.
TIA,
Kristine Fierce
Ag Leader Technology
aidacra
(Nathan your friendly neighborhood Support Engineer)
2
Try uninstalling your existing Epicor ICE Task Agent from Programs & Features, and reinstalling from \ERP10\ERP10.1.600.0\Updates\ERP10.1.600.8\SupplementalInstalls\Task Agent.
This sounds like a bug that was fixed in .4, but, needed to install the latest TaskAgent to get the fix.
Nathan,
We are having a similar issue, but we are on a Test database running 10.2.200.8. If I run a daily schedule Mon-Fri but set the start time to 8pm est (12:00 UTC), its like the system gets confused and starts running Sunday - Thursday. If I change it to 7:59pm or 8:01pm then life is good. The only thing support is telling me to do is delete the schedule (which I have done already) and now delete the entire system agent and then re-create. I don’t think that is going to resolve the issue because it sounds like a lot of people are noticing this issue. Would you be willing to take a look at this open Epicor ticket?
Case CS0001094008 Comments Added - Tech UTC bug with MRP daily schedule time of exactly 8pm Thru System Agent Task, MRP does not run at scheduled time
Derek
aidacra
4
Happy to look, and not saying it shouldn’t work, but, is not rescheduling it +/1 a minute as a semi-permanent workaround until we can get to the bottom of it not an option?
