Syntax error returning calculated field
I’m getting an error when I try to add a calculated field in a BAQ.
Incorrect syntax near the keyword ‘as’.
The SQL looks right to me, but my SQL is rusty.
select
	[OrderRel].[OrderNum] as [OrderRel_OrderNum],
	[OrderRel].[OrderLine] as [OrderRel_OrderLine],
	[OrderRel].[OrderRelNum] as [OrderRel_OrderRelNum],
	[OrderDtl].[PartNum] as [OrderDtl_PartNum],
	[OrderDtl].[LineDesc] as [OrderDtl_LineDesc],
	[OrderDtl].[OrderQty] as [OrderDtl_OrderQty],
	[OrderDtl].[CustNum] as [OrderDtl_CustNum],
	[OrderDtl].[RequestDate] as [OrderDtl_RequestDate],
	[OrderDtl].[NeedByDate] as [OrderDtl_NeedByDate],
	(Part.PartNum is null or Part.NonStock = 1) as [Calculated_MakeToOrder] -- ERROR HERE
from Erp.OrderRel as OrderRel
left outer join Erp.JobProd as JobProd on
	OrderRel.Company = JobProd.Company
	and OrderRel.OrderNum = JobProd.OrderNum
	and OrderRel.OrderLine = JobProd.OrderLine
	and ( JobProd.JobNum is null )
inner join Erp.OrderDtl as OrderDtl on
	OrderRel.Company = OrderDtl.Company
	and OrderRel.OrderNum = OrderDtl.OrderNum
	and OrderRel.OrderLine = OrderDtl.OrderLine
left outer join Erp.Part as Part on
	OrderDtl.Company = Part.Company
	and OrderDtl.PartNum = Part.PartNum
where (OrderRel.Make = 1)
Everything else works fine and returns the expected rows. What am I doing wrong with the calculated field?
case when (Part.PartNum is null or Part.NonStock = 1) then 1 else 0 end
That works after replacing true and false with 1 and 0. Thanks.
give Brian a ‘solved’ for is efforts :wink:
