Mike
Can you please give me the steps involved in vantage 6.10.
Thank you
ZR
Thank you
ZR
--- In vantage@yahoogroups.com, "Mike Lowe" <MLowe@...> wrote:
> For 6.1 you still can't update the costing method with an onhand
> quantity of parts. So you qty adjust the parts to zero, change costing
> method from STD to Last and then qty adjust the parts back.
> Mike
> Of chllee72
> Sent: Wednesday, January 20, 2010 10:05 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Switching costing Method
> I remember that we purchased one program thru Epicor to update Standard
> Cost.
> The program did export from excel to Vantage.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "zuhaib_akhtar" <zuhaib_akhtar@> wrote:
> > > > Gerry
> > I am sorry I have not mentioned before I am using Vantage 6.10.
> > i was not able to see part tab there.
> > Actually I want to switch to last cost whatever it was.
> > thank you
> > ZR
> "batlou" <brian.chandler@> wrote:
> > > We switched from Average to Standard Cost. See below for the Project
> Plan. These task were assigned to various people in our Organization and
> took about 4 hours to complete.
> > > Each report that was created was attached to the task for review at
> a later date.
> > > Good Luck.
> > > 1. Establish Reason Code
> > > 2. Verify Standard Cost
> > > 3. Print Part Cost Variance Dashboard
> > > 4. Write off Scrap and First Articles
> > > 5. Cease all Transactions in Vantage
> > > 6. Print Part Cost Variance
> > > 7. Backup Vantage
> > > 8. Run Stock Status Report
> > > A. Export to Excel so P/N's can be cut and pasted during QTY
> adjustment process.
> > > B. This document should be used later to check against the final
> stock status report.
> > > 9. Run COGS/WIP Report
> > > 10. Divide Stock Status up between Users
> > > A. Take out finished good inventory that is on-hand.
> > > B. Highlight stock status as each row is adjusted.
> > > C. Take out all components of that finished goods using the quantity
> adjust. Highlight stock status as each row is adjusted.
> > > D. Use the Standard cost reason code during adjustments.
> > > 11. Run Stock Status Report
> > > A. Verify all stock has been removed from Vantage.
> > > 12. Run Conversion Script (SQL Code)
> > > A. Convert Average to Standard Cost
> > > B. Turn off Track Lots on all parts
> > > C. Set Standard Cost as default for all new parts.
> > > 13. Sample 10 Parts
> > > A. Add Qty's back to Vantage
> > > B. Verify Part Entry
> > > C. Verify Qty's
> > > D. Verify Lots
> > > E. Verify Cost Type
> > > F. Materials Manager will confirm parts and Go-No Go
> > > 14. Return Qty's back to Inventory
> > > 15. Run Stock Status
> "Gerry Loranger" <gloranger@> wrote:
> > > > Sure, just go into the Part Master and change it in the Part tab.
> I'm
> > > > guessing you have inventory on hand and it's disabled. If so, you
> will have
> > > > to zero it out to change the costing method and then re-add it
> after you've
> > > > made the change.
> > > > Gerry
> > > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > > > zuhaib_akhtar
> > > > Sent: Wednesday, January 20, 2010 9:02 AM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > Subject: [Vantage] Switching costing Method
> > > > Is there any way to switch costing method????
> > > > Please reply.
> > > > thank you
> > > > Z R
> > > > [Non-text portions of this message have been removed]
> ______________________________________________________________________
> This email has been scanned by the MessageLabs Email Security System.
> For more information please visit http://www.messagelabs.com/email
