(SURVEY) GL and Inventory
I agree!
> -----Original Message-----
> From: Alex Neutgens [mailto:alex.neutgens@...]
> Sent: Tuesday, January 30, 2001 1:57 PM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] (SURVEY) GL and Inventory
> We run the Capture cos/wip the second day of each month.
> This gives us a
> chance to update labor records before they are locked (which is what
> happens when you run the capture). We also run reports to
> try and catch
> some of the errors. I would only run it more often than that
> if you are
> confident your labor records will not need to be changed. I
> know myself
> and others have requested to Epicor that labor records not be
> locked when
> the capture is run. My feeling is the system should be able
> to log changes
> and interface the changes to the GL at the time of the next capture.
> Alex Neutgens
> Controller
> Circuit Check, Inc.
> 763-694-4110
> From: Wendy Bowen (Pursche) [SMTP:wpursche@...]
> Sent: Tuesday, January 30, 2001 12:58 PM
> To: Vantage Yahoogroups list
> Subject: [Vantage] (SURVEY) GL and Inventory
> I'm forwarding this from my Controller:
> We are just beginning to interface our general ledger and inventory
> modules. One issue that has come up is running the capture
> cos/wip. Our
> staff is reluctant to run the process more than just at month end, as
> making corrections is not as easy.
> How often do you run the capture cos/wip? For those of you
> who run it more
> than once a month, do you run up to the current date or
> select a date prior
> to the current date?
> Thanks for your input!!
> Robbie McColgan
> Controller
> Schmald Tool & Die, Inc.
> (810) 743-1600 ext.336
> rmccolgan@...
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
> ------------------------ Yahoo! Groups Sponsor
> eGroups is now Yahoo! Groups
> Click here for more details
> http://click.egroups.com/1/11231/1/_/411782/_/980885742/
> -------_->
We are just beginning to interface our general ledger and inventory modules. One issue that has come up is running the capture cos/wip. Our staff is reluctant to run the process more than just at month end, as making corrections is not as easy.
How often do you run the capture cos/wip? For those of you who run it more than once a month, do you run up to the current date or select a date prior to the current date?
Robbie McColgan
Controller
rmccolgan@...
We're on 4.0; and run the capture once a month, at the end of the month
after the last payroll containing any of the days for that month is posted.
Easier to make corrections to payroll before the capture rather than after.
Occasionally, I will need to post a second time for a given month end. ie.,
I won't run the wip capture for January until all labor has been proofed for
January - which is likely to be 2/6/01.
Deb Wilmoth
Reeder & Kline Machine Co.
Sent: Tuesday, January 30, 2001 1:58 PM
Robbie McColgan
Controller
rmccolgan@...
We run the Capture cos/wip the second day of each month. This gives us a
happens when you run the capture). We also run reports to try and catch
some of the errors. I would only run it more often than that if you are
confident your labor records will not need to be changed. I know myself
and others have requested to Epicor that labor records not be locked when
the capture is run. My feeling is the system should be able to log changes
Alex Neutgens
Controller
Circuit Check, Inc.
763-694-4110
Robbie McColgan
Controller
rmccolgan@...
Once a month, I run it for the last day of the previous month and usually
run it when all my a/p has been posted for the month. Usually that means we
run capture around the end of the 1st week.
Kathy Hambleton
Electron Energy Corporation
Robbie McColgan
Controller
rmccolgan@...
Our procedure is to run it at month end only.
Jerry Boyle
Sipco Molding Technologies
Meadville, Pa. 16335-6725
814.724.2243
Visit our web site at www.sipco.com
we're running version 4.0 without payroll integration. i usually run this a
couple of days before month end (like today), then run a quick income
statement to make sure the COS number is what i'm expecting. if there is
some problem, it gives me a day or so to run it down before the month is
closed. then, of course, we run it again as part of month end. james
Sent: Tuesday, January 30, 2001 11:58 AM
Robbie McColgan
Controller
rmccolgan@...
Robbie;
We run it once a month, after we make sure all labor transactions have been
updated/corrected. Once this process is run it freezes labor/payroll
transactions if you are using data collection.
We don't feel we have the personal to track this closer, although we likely
could.
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
An Excaliber Company
e-mail - Warren.Eddy@...
phone - 219 478-2363 ext 217
fax - 219 478-1043
Robbie McColgan
Controller
rmccolgan@...
