Did you activate the Data directive ChangeLog ? if so, you can look into the log tables,( [Ice].[ChgLog])
if not Maybe via other related tables to have best estimate? otherwise a UD field…
I find disapointing that the Epîcor tables did not follow a common design amongst all tables such as Creation date, creation user which would have been helpfull in different areas…
@Ruben_Corral_Yrureta If you did not turn on the Data Directive or add the field at the very start of your instance, you will not be able to get the dates for the suppliers.
well then I´m afraid I won´t be able to… my last thought is to, now that the UD field is created… recreate all the suppliers… thank you all for your responses.
Maybe look at the first date of purchase from each supplier, as a creation date maybe? At least more meaningfull then recreate them all… then use DMT to update your UD field
