Supplier Tracker Parts Tab
Not sure if this is all I need to check, but this is what I found.
In Part Plant we have a buyer for a part not showing up in the supplier
tracker. I added myself as an authorized user for that buyer. I reran the
tracker and the part is not showing up. Is there something else I need to
check for the correct permissions? And does the tracker only show parts
from the supplier that the user is allowed to buy versus all buyers can buy?
Vic Drecchio
Sent: Wednesday, August 07, 2013 2:55 PM
Subject: RE: [Vantage] Supplier Tracker Parts Tab
The Buyer's are all set up correctly with appropriate permissions?
Behalf Of
mike.numbers
Sent: Wednesday, August 07, 2013 2:49 PM
Subject: [Vantage] Supplier Tracker Parts Tab
9.04.507a
Any ideas on why parts are not showing up on the supplier tracker? We have
no parts showing under active for a supplier and 3 parts showing when we
click on All. The supplier is associated with the part in the Plants tab of
the Part maintenance program. The part is NOT inactive. Help says all parts
that are sold to us from the supplier should appear here. The part type is
Purchased. when I run a BAQ against PartPlant for this supplier, I get
hundreds of parts. Is this our problem or an Epicor problem?
9.04.507a
Any ideas on why parts are not showing up on the supplier tracker? We have no parts showing under active for a supplier and 3 parts showing when we click on All. The supplier is associated with the part in the Plants tab of the Part maintenance program. The part is NOT inactive. Help says all parts that are sold to us from the supplier should appear here. The part type is Purchased. when I run a BAQ against PartPlant for this supplier, I get hundreds of parts. Is this our problem or an Epicor problem?
mike.numbers
9.04.507a
