Supplier Performance
Supplier Performance. How does this function work? How are the ratings set up?
Supplier performance is a place that you can update it manually.
There isn’t any automatic way of updating the fields.
Same with on-time performance. There is not a good dashboard to monitor the on-time delivery of products.
For both, you can use the Receipt detail table that will show the date received vs the due date on the PO release. There are also some fields for inspection with pass and fail.
