Summing group footer amounts
Brian,
Thanks, Running Totals was the answer.
Mike
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Mike, as a possible alternative to all these formulas... look at running
> totals in Crystal. You can have a value total only at the change of
> some other fields or group, and when it resets. Haven't looked at your
> original requirements in details, but might work for you.
> Brian.
> Of Mike Numbers
> Sent: Tuesday, September 11, 2012 3:41 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Summing group footer amounts
> I see how this is supposed to work, but when I create my "LaborTally"
> field
> it ends up be a Boolean type field. Below is my formula. I have tried it
> with Global in front of CurrencyVar and without Global. Do you see what
> I
> am doing wrong? This is copied from the Formula Workshop window when I
> create a new formula and give it a name of LaborTally.
> CurrencyVar LaborTally;
> if (Previous
> ({BAQReportResult.QuoteOpr.OprSeq})<>{BAQReportResult.QuoteOpr.OprSeq})
> then LaborTally = (LaborTally + {@LaborCost})
> else LaborTally = (LaborTally)
> Mike
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> Vic Drecchio
> Sent: Tuesday, September 11, 2012 3:00 PM
> Sorry, not a "shared" variable; *global* variable.
> Check this out. It should kickstart you:
> http://www.youtube.com/watch?v=DNJfG0Af3wM
> Behalf Of
> Mike Numbers
> Sent: Tuesday, September 11, 2012 2:52 PM
> I am not following you. I looked up shared variable and it appeared to
> be
> used with sub reports. I currently am not using a sub report. I also did
> not understand how the PreviousFld function would work in your
> situation.
> It sounds like what I had tried.
> Any chance of explaining in more detail. It's just not registering right
> now.
> Mike
> Behalf Of
> Vic Drecchio
> Sent: Tuesday, September 11, 2012 2:26 PM
> You can't use PreviousFld in a Sum because it occurs during the
> WhenPrintingRecords phase of the report.
> You'll have to create a shared variable. In that shared variable. call
> it
> "LaborTally" and then you will be able to use your PreviousFld function
> and
> tally up the total. Then display that tallied field in your RF.
> Behalf Of
> mike.numbers
> Sent: Tuesday, September 11, 2012 2:18 PM
> Subject: [Vantage] Summing group footer amounts
> I am trying to create a report to replace the Quote Worksheet. My BAQ
> links
> the QuoteMtl and QuoteOpr by line and Oprseq/RelatedOprSeq. I am
> printing
> the QuoteMtl in detail time and QuoteOpr in group footer time. The
> report is
> printing correctly. My problem is when I try to get totals. I am summing
> the
> material cost from the detail line and that value is correct. When I sum
> the
> labor costs from the group footer operation level, I am getting an
> inflated
> amount because my QuoteOpr line is internally duplicated for each
> material.
> I tried using Previous Fld to create a workfield that would be 0 if the
> previous oprseq = the current oprseq. There were no errors in the
> formula.
> When I put the work field on the report, it shows it is a number. When I
> click on the summation icon the new field does not come back in the
> field to
> be summarized.
> Is there another way to get the report to sum only the fields printing
> and
> not the duplicate values in the BAQ or am I doing something wrong when
> creating the work field using Previous Fld?
> Any help would be appreciated.
> Mike
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2221 / Virus Database: 2437/5262 - Release Date:
> 09/11/12
> 09/11/12
> 09/11/12
> 09/11/12
I am trying to create a report to replace the Quote Worksheet. My BAQ links the QuoteMtl and QuoteOpr by line and Oprseq/RelatedOprSeq. I am printing the QuoteMtl in detail time and QuoteOpr in group footer time. The report is printing correctly. My problem is when I try to get totals. I am summing the material cost from the detail line and that value is correct. When I sum the labor costs from the group footer operation level, I am getting an inflated amount because my QuoteOpr line is internally duplicated for each material. I tried using Previous Fld to create a workfield that would be 0 if the previous oprseq = the current oprseq. There were no errors in the formula. When I put the work field on the report, it shows it is a number. When I click on the summation icon the new field does not come back in the field to be summarized.
Is there another way to get the report to sum only the fields printing and not the duplicate values in the BAQ or am I doing something wrong when creating the work field using Previous Fld?
Mike
I have a report for Part Costing...I have 3 sub reports (Mtl, Oper and Sub Contract) - each then has their own total on the subreport. All subreports are linked by the part and revision...I then use shared variables to get the total part cost. This may be a different way for you to go...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mike.numbers
Sent: Tuesday, September 11, 2012 1:18 PM
Mike
You'll have to create a shared variable. In that shared variable. call it
"LaborTally" and then you will be able to use your PreviousFld function and
mike.numbers
be summarized.
Mike
Version: 2012.0.2221 / Virus Database: 2437/5262 - Release Date: 09/11/12
I am not following you. I looked up shared variable and it appeared to be
not understand how the PreviousFld function would work in your situation.
now.
Mike
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
Mike Numbers
now.
Mike
Behalf Of
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
I see how this is supposed to work, but when I create my "LaborTally" field
with Global in front of CurrencyVar and without Global. Do you see what I
if (Previous
Mike
Vic Drecchio
Behalf Of
Mike Numbers
now.
Mike
Behalf Of
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
That looks fine to me except that I always declare "WhilePrintingRecords;"
as the first line in the formula. I updated yours below.
I typically display my shared/global variables with a second formula. Take
*that* formula and dump it in your RF.
So, say for instance you have your formula for tallying the data and the
contents of the formula would be what you show below. For the sake of this
example, we'll call that formula fLaborTally.
Then I'll create a second formula that simply displays the current value of
the shared/global variable in whichever appropriate report section. I'll
call this formula fLaborTallyDisplay.
The contents of the "display" formula, fLaborTallyDisplay, would be:
Global CurrencyVar LaborTally;
Just those two lines. Then I'll drag fLaborTallyDisplay out onto the
report.
HTH.
Mike Numbers
if (Previous
Mike
Behalf Of
Vic Drecchio
Behalf Of
Mike Numbers
now.
Mike
Behalf Of
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
FYI,
I have got the field to be a currency field now. My calculation is not
picking up the first operation and doubling the last operation. I have to
go back and check my data and see if I am using PreviousFld correctly.
Thanks for your help
Mike
Mike Numbers
if (Previous
Mike
Behalf Of
Vic Drecchio
Behalf Of
Mike Numbers
now.
Mike
Behalf Of
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
FYI,
I sent my previous update @ 4:27 before I saw this. I will try it and see
if it makes a difference.
Thanks again,
MIke
Vic Drecchio
Sent: Tuesday, September 11, 2012 4:24 PM
report.
HTH.
Behalf Of
Mike Numbers
if (Previous
Mike
Behalf Of
Vic Drecchio
Behalf Of
Mike Numbers
now.
Mike
Behalf Of
Vic Drecchio
Behalf Of
mike.numbers
be summarized.
Mike
Brian.
Of Mike Numbers
field
I
if (Previous
Mike
Behalf Of
Vic Drecchio
Behalf Of
Mike Numbers
be
situation.
now.
Mike
Behalf Of
Vic Drecchio
it
and
Behalf Of
mike.numbers
links
printing
report is
the
the
inflated
material.
formula.
field to
be summarized.
and
Mike
09/11/12
09/11/12
09/11/12
09/11/12
