Hoping someone can assist us (Epicor have said the issue is with us…)
Since 2 days ago, we are getting intermittent errors when printing, 80% of prints are failing, however, all previews are OK.
Regardless of initiating via Report Routing / Directive printing, they nearly all fail.
APR Error
An error occurred while performing print routing action Server Print: The report could not be printed because of the following reason: PRINTER_DOESNT_EXIST
We have tried the following:
Different Users initiating report/print.
Different Reports.
Different Printers.
Removing/Recreating Printers in Epicor.
Removing/Recreating Printers on the Server.
Restarted App Pool.
Restarted App Server.
Restarted SQL Server Reporting Service.
Restarted SQL Server.
There is plenty of space on the servers, backups are working fine, memory is not an issue. We have made no changes to these servers or our network infrastructure in many weeks.
Last night, every server on our network was updated and rebooted. The issue persists today.
For context; we do not use the Advanced Print Routing module. We are using standard SSRS and Report Style Breaking & Routing. Printers are directly installed on the Epicor App server itself, so we are not using a print server as such. However, we have also tried this…
We are still on 10.2.300.41 (Kinetic is being tested on another server).
We have made no updates/changes to the App Server or SQL Server.
Currently, we have just created the Live environment on our Pilot server and it seems to be behaving - suggesting something is amiss with our Live Server.
This is not ideal, as ALL shares/printers/services/certificates etc. would need to be moved too… The best solution for us is to find the cause of the issue.
We didn’t try a new B&R style, as, because it works 20% of the time, surely it must be ok… and this issue has suddenly affected a dozen plus reports.
I may have been mistaken about my understanding of APR and B&R, but, as for the error with full stack, please advise best way to get this, as all we can see is the error in System Monitor history (detailed above).
Interesting, we’ve just been informed of another of our users having this issue, this time against a non B&R initiated report, printed with standard print dialog to a Server Printer.
Here is the full error from System Monitor:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: The report could not be printed because of the following reason:
Stack Trace:
at Ice.Core.SsrsReporting.PdfReportPrinter.Print(Byte[] reportBytes, String printerNameParameter, String reportDescription, EpiPrinterSettings printerSettings, EpiPageSettings pageSettings) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\SsrsReporting\PdfReportPrinter.cs:line 39
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPrintOrEmailReport(RenderedSsrsReport renderedReport, Boolean serverSidePrint, Boolean ignorePageSettings) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 359
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport, Func`3 filterTableAttachmentsFunc) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 57
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
at Ice.Core.RptTaskBase`1.XMLClose() in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 216
at Erp.Internal.JC.JobTrav.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_projects\ERP\RL10.2.300.0\Source\Server\Internal\JC\JobTrav\JobTrav.cs:line 688
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ICE\ICE3.2.300.41\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\ICE3.2.300.41\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\ICE3.2.300.41\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 577
This is the first time we’ve seen the full error, normally it’s just the shortened version we see with the B&R fails.
We are currently running Epicor 10.2.300.41 on Server 2012 (Which is about to be out of Microsoft support), so we have been preparing a new Server 2016 for Epicor 10 (2016 is the highest officially supported for this version of Epicor).
Fresh server build, fresh install of Epicor 10.2.300.41, Registered SQL and our Live environment including SSRS. Limited testing and seems to be working, but no where near ready to move over due to shares/ssl certs/full testing of customizations etc.
It seems having this server running was the cause of the issue… Our printing and reporting has been perfect since taking it offline.
Any tips on the correct way to replicate our environment on to a new server?
We also have another Server 2012 running Pilot and Test, this does not give us issues. We even put Live on there for troubleshooting this week and it does not interfere as it does when on 2016.
