Subscriber/Dependent Combo Box in BAQ Report Interface
I have a BAQ report that is filtered on Part Number and Lot Number. These are options (not filters) in the BAQ Report Designer, resulting in Textboxes. To ease user input, I replaced these with Combo Boxes. The first is a BAQ Combo showing a limited list of Part Numbers matching the desired list to be selected for this particular report. I would like the second Combo Box to only show lots for the part selected in the first box.
I watched this video (thanks Jose) and implemented what I could:
First box: BAQCombo bound to ReportParam.Field1
Second Box: EpiCombo bound to ReportParam.Field2
EpiBOName: ERP:BO:LotSelectUpdate
EpiHiddenColumnsAppend: PartNum
EpiFiltersAppend: PartNum = ?[Field1, “”]
Error when clicking the dropdown on the Lot Combo Box:
“Error accessing the database: Conversion failed when converting the nvarchar value ‘X’ to data type int.”
where X is some random unrelated lot tracked part.
I can’t figure out where I have introduced an integer since everything should be strings.
Thanks in advance for any help!
I found Jason Wood’s reply to another question about combo boxes that helped me here. I was able to solve this with his screenshot found in this post.
Box 2 properties:
EpiFilters: PartNum = ‘?{Field1Column,’‘}’
EpiFiltersParams: Field1Column=?[Field1]
You can mark your own posts as the solution.
Hi Craig I’m having the same issue and have created a BAQ report so production can reprint material tags. But have not had any success getting my second combo working. Any guidance would be greatly appreciated.
Michael,
Can you share what you have tried so far? I found the screenshot in Jason’s post linked above to be useful for getting the right filter properties.
