Styling / Themes / Colors
PERFECT! - Thanks a lot Brian.
Greg
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Greg, I have a style file that does this, included below. Adds a
bright
> orange background to test database toolbar & status bar. It's not
> perfect, also grays out some of the read only controls, but works well
> enough - it's a bright! orange. Implemented by customizing the client
> test.mfgsys file, there's a setting somewhere in it for a default
style
> file.
> Brian.
> --- TestBackground.isl ---
> <?xml version="1.0" encoding="utf-8"?>
> <styleLibrary>
> <annotation>
> <lastModified>2011-06-24T12:07:21</lastModified>
> </annotation>
> <styleSets defaultStyleSet="Default">
> <styleSet name="Default">
> <styles>
> <style role="MainMenubarHorizontal">
> <states>
> <state name="Normal" backColor="Orange"
> backGradientStyle="None" backHatchStyle="None" />
> </states>
> </style>
> <style role="ToolbarDockAreaTop">
> <states>
> </states>
> </style>
> <style role="ToolbarHorizontal">
> <states>
> </states>
> </style>
> <style role="ToolbarItemComboBox">
> <states>
> </states>
> </style>
> <style role="UltraStatusBar">
> <states>
> </states>
> </style>
> </styles>
> </styleSet>
> </styleSets>
> </styleLibrary>
Behalf
> Of greg_clauser
> Sent: Monday, August 06, 2012 4:52 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Styling / Themes / Colors
> Yes, I got the pdf. I actually already had it in the application
manual
> and I'm sure it covers anything and everything there is to know about
> Styling and Themes. It's 38 pages long and I'm not interested in
> becoming an expert just to change a color.
> All I want to do is change the color of the header bars in the test
> database so it will be very easy to see which database you are in. I
was
> hoping it was something easy but I guess not.
> Thanks,
> Greg
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> Miguel Santillan msantillan@ wrote:
> > Did you get the PDF I sent you?
> > Miguel A. Santillan
> > Compass Components, Inc.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]
On
> Behalf Of greg_clauser
> > Sent: Monday, August 06, 2012 7:41 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Thanks, I think this is what I was looking for but I'm still a bit
> confused.
> > I got to Runtime Styler, hovered and got the popup menu and the new
> EpiResources panel. Not sure where to go from here. There are so many
> things to choose. I just want to change the color of the top and
bottom
> bars on the screen. Do I have to create a new active styleset first? I
> also don't see how to save any changes?
> > Greg
> <mailto:vantage%40yahoogroups.com>, Greg Payne
<gpayne@<mailto:gpayne@>>
> wrote:
> > > Options > Styling > Runtime Styler.
> > > Hover over the area you want to change and a popup menu appears.
> press the letter of the area you want to change.
> > > A new panel will open where you can change the colors.
> > > Save when finished.
> > > Then use Options > Theme maintenance to bring up your saved style
> and check distributable, save. The under actions click Make Theme
> Default.
> > > I have to reset default, each time I copy database. I know I have
> seen discussion on how to invoke styling by code, but I have never
done
> it.
> > > HTH
> > > Greg Payne
> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
> On Behalf Of greg_clauser
> > > Sent: Friday, August 03, 2012 4:56 PM
> > > Subject: [Vantage] Styling / Themes / Colors
> > > I worked for years up through Vantage 6.15 or so and in there it
was
> easy to change the color of the header bar, etc. We always kept a test
> database that was at most a week old copy of our live database so
people
> could experiment. I would make the color scheme for the test database
> green rather than blue so that it was obvious which database you were
> in.
> > > I'm now implementing Epicor 9.05.700b at a new company and want to
> make the same kind of color changes but it's not too clear how to do
it.
> I know it's in stylings somewhere but it's not very intuitive. One of
> the Epicor consultants even sat down to show me how easily it could be
> done but even he could not remember how.
> > > Anyone out there figure it out?
> > > Greg
> > > ________________________________
> > > CONFIDENTIALITY NOTICE
> > > The information contained in this communication, including
> attachments, is privileged and confidential. It is intended only for
the
> exclusive use of the addressee. If the reader of this message is not
the
> intended recipient, or the employee or agent responsible for
delivering
> it to the intended recipient, you are hereby notified that any
> dissemination, distribution or copying of this communication is
strictly
> prohibited. If you have received this communication in error, please
> notify us at (727) 578-6258 and immediately delete the communication.
> > > "This (document/presentation) may contain technical data as
defined
> in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
> Export of this material is restricted by the Arms Export Control Act
(22
> U.S.C. 2751 et seq.) and may not be exported to foreign persons
without
> prior approval form the U.S. Department of State."
I worked for years up through Vantage 6.15 or so and in there it was easy to change the color of the header bar, etc. We always kept a test database that was at most a week old copy of our live database so people could experiment. I would make the color scheme for the test database green rather than blue so that it was obvious which database you were in.
I'm now implementing Epicor 9.05.700b at a new company and want to make the same kind of color changes but it's not too clear how to do it. I know it's in stylings somewhere but it's not very intuitive. One of the Epicor consultants even sat down to show me how easily it could be done but even he could not remember how.
Greg
Hover over the area you want to change and a popup menu appears. press the letter of the area you want to change.
Save when finished.
Then use Options > Theme maintenance to bring up your saved style and check distributable, save. The under actions click Make Theme Default.
I have to reset default, each time I copy database. I know I have seen discussion on how to invoke styling by code, but I have never done it.
HTH
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of greg_clauser
Greg
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Do you have access to EpicWeb?
Documents > Epicor 9 > Release 9.05.700 > EpicorUserExpCust_UserGuide_905700_*
It is in Chapter 2....
Miguel A. Santillan
Sent: Friday, August 03, 2012 1:56 PM
Greg
Thanks, I think this is what I was looking for but I'm still a bit confused.
I got to Runtime Styler, hovered and got the popup menu and the new EpiResources panel. Not sure where to go from here. There are so many things to choose. I just want to change the color of the top and bottom bars on the screen. Do I have to create a new active styleset first? I also don't see how to save any changes?
Greg
> Save when finished.
> HTH
> Greg Payne
> Greg
Miguel A. Santillan
Greg
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg Payne <gpayne@...<mailto:gpayne@...>> wrote:
> Save when finished.
> HTH
> Greg Payne
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of greg_clauser
> Greg
Yes, I got the pdf. I actually already had it in the application manual and I'm sure it covers anything and everything there is to know about Styling and Themes. It's 38 pages long and I'm not interested in becoming an expert just to change a color.
All I want to do is change the color of the header bars in the test database so it will be very easy to see which database you are in. I was hoping it was something easy but I guess not.
Greg
> Miguel A. Santillan
> Greg
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg Payne <gpayne@<mailto:gpayne@>> wrote:
> > Save when finished.
> > HTH
> > Greg Payne
> > Greg
Greg, I have a style file that does this, included below. Adds a bright
test.mfgsys file, there's a setting somewhere in it for a default style
file.
Brian.
<styleLibrary>
<annotation>
</annotation>
<styles>
<states>
</states>
</style>
<states>
</states>
</style>
<states>
</states>
</style>
<states>
</states>
</style>
<states>
</states>
</style>
</styles>
</styleSet>
</styleSets>
</styleLibrary>
Of greg_clauser
Greg
> Miguel A. Santillan
confused.
> Greg
> > Save when finished.
Default.
it.
> > HTH
> > Greg Payne
in.
> > Greg
I used the easy example of clicking on the status bar and changing it to a different color. Looks great on my PC, but in our training room and some of the desktops it looks terrible on customized forms - throws big black blobs around things (at least they aren't where data elements are). We are all on Win 7 so it's not an XP vs. Win7 issue. I really wish it was as easy as you hoped!
