I am running a BAQ in code and dumping the results into an UltraGrid. Everything works great as usual except when I noticed that if my BAQ resulted in no records, the grid remains unchanged with the old data.
A simply solution I found was to set the UltraGrid.DataSource = null before running the BAQ and populating results. The problem is that after the first successful query, I run another query and the results do no display properly (I can verify that I have records in the results). The grid gets a strange arrow, see picture:
You should make an EpiDataView for the BAQ Results then use DataSet merge for the results and DataTable clear so that you don’t loose the formatting.
EpiDataView edv = new EpiDataView();
edv.dataView = dt.defaultView;
oTrans.Add("MyAewsomeView, edv);
now you have a working EpiDataView and any data added to the dt data table… will do its thing… You can bind grids to it , fire notifications … the works
Now you can expand that by instead of using a standard DataTable you can execute your query and get back the DataSet.Tables[“Results”] and make said Results table your DataTable for the EpiDataView… then use dataSet.Merge() to update or add to the table… etc…
Sorry I am slammed today so I can’t give you a spoon fed example, but this should get you close
One of these days I am going to have to get some schooling on oTrans, DataViews, and the likes (maybe I will learn this in Customization classes at Insights2017)
By changing MyGrid.DataSource = dqa.QueryResults to
MyGrid.DataSource = dqa.QueryResults.Tables[“Results”]; seems to have made the issue go away.
Sorry to highjack this thread but would anyone be able to share an example of how to use dataset.Merge() to update an EpiDataView as mentioned earlier in post?
