Strange things after Upgrade from 9.05.600c to 9.05.601b
FYI - Update
I upgraded from 9.05.600c to 9.05.601b on SQL 64 bit. Since then I have found:
1. The file <server>\Epicor905\Server\config\mfgsys.pf file had this entry: -db "D:\epicor905\db\training\mfgsyssh" -RO
2. The client file: <drive>\Client905\Client\config\default.mfgsys file is missing all of the user settings. The current file, starting at the closing if the appSettings looks like this:
</appSettings>
<userSettings />
<deploymentSettings>
3. Cannot print a BAQ report if filtering is used. Goes straight to history in System Monitor with error "No records selected"
4. Adding a process in menu maintenance is acting like it did in 600c before the "fix" was created for version 601.
Currently waiting on Epicor to provide explanations.
Jeff Sanders
