State of Temp Tables in BPM
Thanks Nigel. I spent some time reworking the original example you gave me, and after a lot of head-banging I was able to get the process to work without having to rely on the ReadyToInvoice flag. I have a BPM without any qualifications on CustShip.Update, and this code (I'll remove the PublishInfoMsg calls when I deploy it).
One thing I discovered about your initial example is that GlbCustCred has multiple rows for a given company for linked Global customers. I had to qualify it further as I couldn't figure out why I wasn't getting the real GlobalCreditLimit for the customer (I was getting the first row back, and there are two returned in my system if I don't qualify it so that GlbCustCred.ExtCompany = ttShipHead.Company).
I have some mysteries about how to deal with flow control in 4GL (the "Return." Statement didn't seem to work as I expected), and the {lib/PublishInfoMsg.i} call mysteriously doesn't do anything if you actually throw a real exception via {lib/PublishEx.i}.
I also couldn't figure out how to properly detect if the ttShipHead record isn't really populated (i.e. you create a new ShipHead, and then immediately add a ShipDtl without specifying the order in the header) so that's commented out.
Anyways, along with checks for CreditHold and OrderHold, this satisfies my requirement (at least based on my testing). I can send along the entire BPM package if folks want it.
Thanks for your help!
-bws
DEFINE VARIABLE InfoMsg as CHARACTER NO-UNDO.
DEFINE VARIABLE ExMsg as CHARACTER NO-UNDO.
DEFINE VARIABLE ShipValue AS DECIMAL INITIAL 0 NO-UNDO.
DEFINE VARIABLE ARTotal AS DECIMAL INITIAL 0 NO-UNDO.
DEFINE VARIABLE GlobalCreditLimit as DECIMAL INITIAL 0 NO-UNDO.
DEFINE VARIABLE ExceededValue AS DECIMAL INITIAL 0 NO-UNDO.
find first ttShipHead where ttShipHead.RowMod = 'A' or ttShipHead.RowMod='U' no-lock no-error.
if available ttShipHead then do:
/* No point in going further if we have no Customer yet in the ShipHead record. */
/* THIS DOESN'T WORK, AS A RESULT ADDING A SHIPDTL TO A BLANK SHIPHEAD RECORD GENERATES A 4GL ERROR.
if NOT ttShipHead.CustNum > 0 then do:
InfoMsg = "No CustNum Defined.".
{lib/PublishInfoMsg.i &InfoMsg = InfoMsg}.
return.
end.
/* First get our current AR Invoice Total for this Customer */
find GlbCustCred where GlbCustCred.Company = ttShipHead.Company and GlbCustCred.CustNum = ttShipHead.CustNum and
GlbCustCred.ExtCompany = ttShipHead.Company no-lock no-error.
if available GlbCustCred then do:
ARTotal = GlbCustCred.ARTotal.
end. InfoMsg = "ARTotal: " + STRING(ARTotal) + " CustNum: " + STRING(GlbCustCred.CustNum).
/* Find the Credit Limit for this Customer */
find Customer where Customer.Company = ttShipHead.Company and Customer.CustNum = ttShipHead.CustNum no-lock no-error.
if available Customer then do:
GlobalCreditLimit = Customer.GlobalCreditLimit.
end.
InfoMsg = "GlobalCreditLimit: " + STRING(GlobalCreditLimit).
/* Find the value of the shipment */
/* for each ShipDtl where ShipDtl.Company = ttShipHead.Company and ShipDtl.PackNum = ttShipHead.PackNum no-lock: */
for each ttShipDtl where ttShipDtl.RowMod = 'A' or ttShipDtl.RowMod = 'U' no-lock:
find OrderDtl where OrderDtl.Company = ttShipDtl.Company and OrderDtl.OrderNum = ttShipDtl.OrderNum and
OrderDtl.OrderLine = ttShipDtl.OrderLine no-lock no-error.
find OrderRel where OrderRel.Company = ttShipDtl.Company and OrderRel.OrderNum = ttShipDtl.OrderNum and
OrderRel.OrderLine = ttShipDtl.OrderLine and OrderRel.OrderRelNum = ttShipDtl.OrderRelNum no-lock no-error.
if available OrderDtl and available OrderRel then do:
if OrderRel.CheckBox01 = False then do:
ShipValue = ShipValue + OrderDtl.UnitPrice * ttShipDtl.OurInventoryShipQty.
end.
end.
end.
InfoMsg = "ShipValue: " + STRING(ShipValue).
ExceededValue = GlobalCreditLimit - ARTotal - ShipValue.
InfoMsg = "ExceededValue: " + STRING(ExceededValue).
if ExceededValue < 0 then do:
ExMsg = "Credit limit exceeded by this shipment by $" + STRING(- ExceededValue) + ". Cannot Ship.".
/* {lib/PublishInfoMsg.i &InfoMsg = ExMsg}. */
{lib/PublishEx.i &ExMsg = ExMsg} {&THROW_PRIVATE}.
end.
end.
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nigel Kerley
Sent: Friday, May 29, 2009 10:09 AM
Subject: [Vantage] Re: State of Temp Tables in BPM
Hi Brian,
A couple of points:
You mentioned "server\bpm\ttable2xml.i". I don't know how access this, but there's a function in the GlbAlert.i file "DumpRecordAsXMLFile". It's explained on P467 of the Tools manual. I haven't looked at it but it may be of use.
Next, I was trying to create a BAM against the ShipHead table some time ago and found the same as you regarding the state of the Ship tables. I eventually created a post-processing directive against the CustShip.Update BO and used a condition of "number of rows in the <query> is equal to one", and query of "for each ttShipHead where ReadyToInvoice=True". That seems to be the last process before an order is "Shipped".
Using this you could try the following code (though you may want to use a pre-processing directive):
find first ttShipHead where ttShipHead.ShipStatus="Shipped" no-lock no-error.
DEFINE VARIABLE ShipValue AS DECIMAL NO-UNDO.
ShipValue = 0.
/* Loop through each line in the shipment to calculate its value */
for each ShipDtl where ShipDtl.Company = ttShipHead.Company and ShipDtl.PackNum = ttShipHead.PackNum no-lock no-error:
InfoMsg = "PackLine: " + STRING(ShipDtl.PackLine).
find OrderDtl where OrderDtl.Company = ShipDtl.Company and OrderDtl.OrderNum = ShipDtl.OrderNum
and OrderDtl.OrderLine = ShipDtl.OrderLine no-lock no-error.
if available OrderDtl then do:
ShipValue = ShipValue + (OrderDtl.UnitPrice * ShipDtl.OurInventoryShipQty).
end.
end.
if ShipValue < <Certain Min Value> then do:
{lib/PublishEx.i &ExMsg = "'Shipment is below min value.'"}
{&THROW_PRIVATE}.
end.
HTH,
Nigel.
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Okay, here's what I'm struggling with. I've finally gotten consensus from my colleagues (sort of) on how to deal with the shipment-related issue I asked about a while back (and got a really great starting point from Nigel).
> I'm trying to come up with the logic in a 4GL BPM pre-processing action custship.update() to properly capture the "proposed value" of the shipment.
> find ttShipDtl where ttShipDtl.RowMod = 'A' or ttShipDtl.RowMod='U' no-lock no-error.
> if available ttShipHead or available ttShipDtl then do:
> ShipValue = 0.
> /* for each ShipDtl where ttShipHead.Company = ShipDtl.Company and ttShipHead.PackNum = ShipDtl.Packnum no-lock: */
> for each ttShipDtl no-lock:
> InfoMsg = "PackLine: " + STRING(ttShipDtl.PackLine).
> and OrderDtl.OrderLine = ttShipDtl.OrderLine no-lock no-error.
> end.
> end.
> It seems like sometimes depending on how I do the update (create new packlist, save, update later, save immediately, change quantity, etc.) I get the data I'm looking for in ttShipDtl, sometimes its in ShipDtl. Note I have a commented-out version of the "for each" loop.
> Basically ShipValue sometimes doesn't get set and I don't enter the foreach loop consistently.
> Do I have to do a 'find' to do a 'for each' or does Progress handle that all for me behind the scenes?
> But more generally I'm not sure how to approach this requirement.
> Basically I want to ensure that a CustShip record doesn't get created and saved that doesn't exceed a certain value, and I'm not familiar enough with how Vantage behaves to understand how to do that to get it to work in all cases.
> -bws
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
> Sent: Thursday, May 28, 2009 10:01 AM
> Subject: RE: [Vantage] State of Temp Tables in BPM
> Funny thing, assumptions...mine was always that the data sets present in
> the trace was that of the temporary tables...if that's not true most of
> the time...then we should all definitely be looking for a better tool to
> debug BPM's... generally speaking I have seen a correlation between
> trace data and what was available in the temporary tables during a
> particular method call...ive still so much to learn yet..
Is there a technique or tool that would let me view the exact state of
all of the temp tables involved in a given BO transaction when writing
BPMs?
I'm finding that my assumptions aren't apparently always true about
what a given client operation is doing, and I'm left scratching my head
wondering whether a given Update() call has the effect I think it has.
I'm wanting some sort of interactive debugger so I can see what's in
those temp tables to begin with. J
That's probably a lot to ask, but is there some way to do this in 4GL?
I see a bunch of utility functions in server/lib (e.g. PublishInfoMsg,
PublishEx) so maybe there's some way to do this. Is there a way to call
"server/bpm/ttable2xml.i"?
Or does the client trace tell me everything I need to know?
-bws
Picometrix
bspolarich@...
<mailto:bspolarich@...> ~ 734-864-5618 ~
www.advancedphotonix.com <http://www.advancedphotonix.com>
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Brian W. Spolarich
Sent: Thursday, May 28, 2009 8:48 AM
Subject: [Vantage] State of Temp Tables in BPM
BPMs?
-bws
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com>
<mailto:bspolarich%40advancedphotonix.com> > ~ 734-864-5618 ~
<http://www.advancedphotonix.com> >
ShipValue = 0.
end.
end.
-bws
Full trace should be enough (but is also very overwhelming and cumbersome).
In a pinch (particularly on the nuggy 404) I resorted to loading the app with every before/after method case I could think of as well as epinotifications (and popping up windows displaying temp values of interest). Not only is that a royal pain, it sometimes changed the behavior of the app so was not always a useful technique.
My kingdom for Visual Studio integration! (;o
Seriously, Progess must have better tools available. They probably aren't cheap though (and also probably are a bear to integrate).
Rob
Â
Sent: Thursday, May 28, 2009 9:48:06 AM
BPMs?
"server/bpm/ ttable2xml. i"?
-bws
Picometrix
bspolarich@advanced photonix. com
<mailto:bspolarich@advanced photonix. com> ~ 734-864-5618 ~
www.advancedphotoni x.com <http://www.advanced photonix. com>
Brian,
Can't help you with the code but can give a word of warning. The Packout apps are buggy (at least through 405a)... Our users have varying entry routines (being a GUI, hard to force a single way) that sometimes leave Shiphead.shipdate null (as an example). We overcame it with our own customization to populate a date## field as a reliable backup.
I haven't looked at the apps in a while but I suspect there are other 'gotcha's there that may be contributing to what you are experiencing (not knowing what version you are on.)
Rob
Sent: Thursday, May 28, 2009 11:15:41 AM
I'm trying to come up with the logic in a 4GL BPM pre-processing action custship.update( ) to properly capture the "proposed value" of the shipment.
find first ttShipHead where ttShipHead.RowMod = 'A' or ttShipHead.RowMod= 'U' no-lock no-error.
find ttShipDtl where ttShipDtl.RowMod = 'A' or ttShipDtl.RowMod= 'U' no-lock no-error.
ShipValue = 0.
InfoMsg = "PackLine: " + STRING(ttShipDtl. PackLine) .
{lib/PublishInfoMsg .i &InfoMsg = InfoMsg}.
ShipValue = ShipValue + OrderDtl.UnitPrice * ttShipDtl.OurInvent oryShipQty.
end.
end.
-bws
    bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Rob Bucek
To: vantage@yahoogroups .com
Funny thing, assumptions. ..mine was always that the data sets present in
Yeah I'm starting to bang my head on this. If I tie this to the "Shipped" box action all is well (as Nigel suggested in his example), but trying to prevent the creation of a shipper at all is giving me fits.
I remember either being contacted or seeing someone post to this list for a company that did contract Vantage customization work. Anyone have any contact info? Relying on the good graces of folks here is a bit much to ask, and Epicor support generally isn't very helpful except in troubleshooting very specific cases.
-bws
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Robert Brown
Sent: Thursday, May 28, 2009 1:11 PM
Subject: Re: [Vantage] State of Temp Tables in BPM
Brian,
Rob
ShipValue = 0.
end.
end.
-bws
That quirk is still out there as of 407...we use packout religiously
though we have narrowly defined our process for the end users. The no
shipdate thing does crop up about once every month or two at the worst.
Of course we only ever notice it after we invoice...just to make it
easier to fix.
Rob Bucek
FAX: 715-284-4084
Of Robert Brown
Sent: Thursday, May 28, 2009 12:11 PM
Brian,
Rob
from Nigel).
shipment.
no-lock no-error.
ShipValue = 0.
oryShipQty.
end.
end.
-bws
Picometrix
Behalf Of Rob Bucek
in
Brian,
Could this be a case where customization might provide and easier solution (versus BPMs)?
Rob
Sent: Thursday, May 28, 2009 1:14:32 PM
-bws
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Robert Brown
Brian,
Rob
____________ _________ _________ __
From: Brian W. Spolarich <bspolarich@advanced photonix. com>
ShipValue = 0.
end.
end.
-bws
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of Rob Bucek
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Perhaps. But given the paucity of starting point documentation for Vantage client customization, I'm not sure how I'd get started there.
Suggestions? I have this great toolkit (well, depending on who you ask here), but so many gaps in my knowledge and no direct ways to fill them (other than trial and error) that its pretty demoralizing. :-)
-bws
Sent: Thursday, May 28, 2009 4:14 PM
Brian,
Rob
-bws
Brian,
Rob
ShipValue = 0.
end.
end.
-bws
Hi Brian,
A couple of points:
ShipValue = 0.
end.
end.
{&THROW_PRIVATE}.
end.
HTH,
Nigel.
> ShipValue = 0.
> end.
> end.
> -bws
