Start/Stop App servers/db batch file
Here are the 2 batch files that I use for our test environment.
Stop Batch:
@echo off
echo Stopping 8.0 Services and Database...
set DLC=e:\Epicor\OE100B
set PATH=%DLC%\BIN;%PATH%
set LIB=%DLC%\LIB;%LIB%
e:
echo .
echo .
echo STOPPING TestEnvironment DB/APPSERVER...
cd \Testenvironment\MfgSys80\db
call asbman -name TestEnvironmentProcessServer -stop
call asbman -name TestEnvironmentTaskServer -stop
call asbman -name TestEnvironment -stop
call dbman -host localhost -port 20931 -database TestEnvironment -stop
echo .
echo .
echo .
echo .
echo .
REM net stop "AdminService for OpenEdge 10.0B"
echo.
echo.
Start Batch:
@echo off
echo Starting 8.0 Services and Database...
e:
echo.
echo.
REM net start "AdminService for OpenEdge 10.0B"
echo STARTING TestEnvironment DB/APPSERVER...
cd e:\TESTENVIRONMENT\mfgsys80\db
call dbman -host localhost -port 20931 -database Testenvironment -start
call asbman -name TestEnvironment -start
call asbman -name TestEnvironmentTaskServer -start
call asbman -name TestEnvironmentProcessServer -start
echo .
echo .
echo .
echo .
echo .
Lori Gustafson
Information Resources
Precision, Inc.
763-852-6718
Of Norman Hutchins
Sent: Thursday, July 31, 2008 11:46 AM
Subject: [Vantage] Start/Stop App servers/db batch file...
Does anyone have a batch file that will stop and/or start the progress
database and the app servers?
Norman
Norman
You can use the bat file already created called: asbman.bat located in
the \epicor\oe101b\bin directory
--sf
> Norman
Use "dbman" to manage the status of the database.
--sf
> Norman
For Application Servers:
@echo off
set DLC=c:\Epicor\OE101B
e:
cd \mfgdata803\Mfgsys803\db
call asbman -name MfgHist803 -start
call asbman -name MfgHist803TaskAgent -start
call asbman -name MfgHist803ProcessServer -start
Replace the part with your own and replace -start with -stop for stopping them.
For the Data Base:
@echo off
set DLC=C:\Epicor\OE101B
e:
cd\mfgdata803\MfgSys803\db
call dbman -host localhost -port 20931 -database MfgHist803 -start
Again replace the path with your own and replace -start with -stop for stopping the database.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415
Sent: Thursday, July 31, 2008 11:54 AM
Subject: [Vantage] Re: Start/Stop App servers/db batch file...
--sf
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Norman Hutchins" <nhutchins@...> wrote:
> Norman
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
