I’m running into an issue where a standard data directive isn’t launching. I have the BPM running after an in-transaction data directive finishes and it was working earlier in the day. I put in a couple of log/notification breaks in both BPMs and I can confirm the in-transaction data directive completes successfully. On the standard directive it won’t even fire the first log where I write a test message to a file.
Is it getting stuck? Where/How can I check to see what might be happening here?
You could also disconnect the code block and throw a message widget in there to confirm if it’s not firing or if it’s just failing on your code silently.
I had a couple of email widgets in there at one point, but I switched to a custom code block because I wasn’t getting the emails. The custom code just wrote a simple message to a file.
This did resolve itself overnight and it seems like the issue was one of our third party consultants running something. Apparently I wasn’t the only one having issues.
