Kyle
For the PO, you can supress the header for pages greater than 1. Right click in
the page header and click on the formula button for "Supress - no drill down"
and put in the following formula "if PageNumber = 1 then no else yes". We
created a 2nd header that prints on pages greater than 2 that is much shorter.
Because the file has so many other modications you find it is easier to modify
your own. Find ours attached any way
Russ Dover
To: <vantage@yahoogroups.com>
Subject: [Vantage] standard crystal forms modifications
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any other MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: WI1 POFORM.RPT
Date: 18 Feb 2003, 18:00
Type: Unknown
Russ Dover
> I don't know if anyone else has this issue, but was wondering if anyone has----------
> solved it. Although you can purchase a standard 3 part check form from Vantage,
> they don't have a standard crystal form that makes full use of the 3 part check
> perforations. Secondly, the standard PO form and AR form uses the 1st half of
> every page to print its header info and therefore makes the number of pages
> printed much longer than necessary as opposed to printing header only on first
> page and then allowing only relevant header info if any be printed on the
> remainder. I have purchased Crystal 8.5 from Vantage to modify but don't want to
> reinvent the wheel if this has been done.
> Does anyone also have these problem and has any modified the standard
> crystal forms in Vantage to allow for:
> 1) in the 3 part check form - repeating information in the 1st part and 2nd part
> so that the 2nd part and check could be sent to vendor while keeping 1st part of
> check for records.
> 2) PO form - only have header info (ie. Company PO #, Vendor, Ship to info,
> terms etc.) only print on the first page while details of PO order just print on
> the remainder of the first page and subsequent pages without the large header
> info.
> 3) AR form - only have header info print on first page and details print on
> remainder of 1st page and subsequent pages.
> thanks for any advice or experience on this.
> Kyle Chin
> Optoplex Corporation
> Internal Virus Database is out-of-date.
> Checked by AVG Free Edition.
> Version: 7.1.362 / Virus Database: 267.13.10/189 - Release Date: 11/30/2005
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> already linked your email address to a yahoo id to enable access. ) (1) To
> access the Files Section of our Yahoo!Group for Report Builder and Crystal
> Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/files/. (2) To search through old msg's
> goto: http://groups.yahoo.com/group/vantage/messages (3) To view links to
> Vendors that provide Vantage services goto:
> SPONSORED LINKS
Type: Unknown
