I have my parts grouped by part number and revision number. Now I want to exclude all parts with all their revision that have ink in them. Not just ink by itself. How do I do that in SSRS or even in a BAQ?
For BAQ:
For your TopLevel, include the PartNum table
Then add a Subquery, use the PartMtl table
Add a Table Critera to PartMtl: MtlPartNum IN specified constant list and include only your Ink Part #s
Go to Display Fields, and just bring over the PartNum (the parent PartNum, not the MtlPartNum)
Go back to Top Level, add a SubQuery critera, something like this: NOT PartNum IN field from Specified Subquery and choose the PartNum field from SubQuery2
So if this is my query/BAQ so far:
select
[ECOMtl].[Company] as [ECOMtl_Company],
[ECOMtl].[PartNum] as [ECOMtl_PartNum],
[ECOMtl].[RevisionNum] as [ECOMtl_RevisionNum],
[ECOMtl].[MtlSeq] as [ECOMtl_MtlSeq],
[ECOMtl].[MtlPartNum] as [ECOMtl_MtlPartNum],
[ECOMtl].[QtyPer] as [ECOMtl_QtyPer],
[ECOMtl].[EstScrap] as [ECOMtl_EstScrap],
[ECORev].[Plant] as [ECORev_Plant],
((case when ECORev.Plant = βMβ then βWCβ else βWCβ end)) as [Calculated_GroupID],
((case when ECOMtl.MtlPartNum Like β%ink%β then βYβ else ββ end)) as [Calculated_Ink]
from Erp.ECOMtl as ECOMtl
inner join Erp.ECORev as ECORev on
ECOMtl.Company = ECORev.Company
And
ECOMtl.GroupID = ECORev.GroupID
And
ECOMtl.PartNum = ECORev.PartNum
And
ECOMtl.RevisionNum = ECORev.RevisionNum
And
ECOMtl.AltMethod = ECORev.AltMethod
group by [ECOMtl].[Company],
[ECOMtl].[PartNum],
[ECOMtl].[RevisionNum],
[ECOMtl].[MtlSeq],
[ECOMtl].[MtlPartNum],
[ECOMtl].[QtyPer],
[ECOMtl].[EstScrap],
[ECORev].[Plant],
((case when ECORev.Plant = βMβ then βWCβ else βWCβ end)),
I would just make my sub query with the same table, correct?
Why not something like.
select
And
And
And
And
Where (ECOMtl.MtlPartNum not like β%ink%β or ECOMtl.MtlPartNum = βinkβ)
@knash I had tried that first, but it just eliminates the line. I want every part that has not ink in any of their revisions. Some of our parts have up to 20 revisions, so I hit 10K lines fast. But I need a way to have Epicor tell me, looking at each part and all their revisions, which ones (parts and/or revision) do not have ink in them.
What @lgraham mentioned seemed to give me quite a few things to look at and it did pull parts that had no revisions, which for us is very odd.
You are trying to return parent parts that donβt have INK in the BOM?
Yes
You will need to add revision to this if it looks like it work, this return Parts that donβt have ink in any revision.
select
where ECOMtl.PartNum NOT IN (
select
Where (ECOMtl.MtlPartNum like β%INK%β and ECOMtl.MtlPartNum <> βINKβ))
This is a bit better
select
where NOT EXISTS (
select 1 from (Select [ECOMtl].[PartNum] as PartNum ,[ECOMtl].[RevisionNum] as Rev
Where (ECOMtl.MtlPartNum like β%083β and ECOMtl.MtlPartNum <> β000-083β)) as partrevs
Where partrevs.partnum = ECOMtl.PartNum and partrevs.Rev = [ECOMtl].[RevisionNum]
