Can you use a BAQ report as a sub-report in another BAQ report? If so how ?
Another SSRS report must be created having at least one common parameter… this is your subreport
Open main SSRS report in design mode
Right click on the design area
Select subreport
Map at least one parameter from the main report to the sub report using Parameters menu in the left panel
