SSRS Rounding
Ok you are right about something being set up wrong. I am manually adding 0.01 to the value and it still shows $900.00. Not sure what it is yet
check the format on the text box in the properties pane if you are using report builder.
Not the number format that you posted above.
Go to a different report that does show decimals and see what is in that format box. Copy that and put it in your format box.
Charles Leclerc I Am Stupid GIF - Charles Leclerc I Am Stupid GIFs
I was printing the FirstHalf variable in both text boxes. Feel free to ridicule me for wasting your time I bet most of those solutions actually worked.
As your penance, you must try each one again and show your work.
That was the worst.
In that case mark mine as the solution, its probably more accruate than @utaylor suggestion :stuck_out_tongue:
Indeed it is!!!
Hello ! If you have this resolved you may ignore this. But what I did is I increased the decimal places during Dividing it by 2
