SSRS Report Order By / Top 1 Syntax - Help Needed
Been trying to get a sort order into this report and cant seem to get the syntax right:
        <CommandText>="SELECT T1.ActTranQty,T4.PONum,T4.PackSlip,T3.RevisionNum,T4.ReceiptDate as TheDate,T5.Name,T6.TypeCode,T1.AsOfDate,T1.AssemblySeq,T1.AssetNum,T1.BurUnitCost,T1.Calc_DocNum,T1.Calc_InvoiceNum,T1.Calc_LineNum,T1.Calc_PrintedBy,T1.Calc_SNList,T1.Calc_VendorAddrList,T1.Calc_VendorID,T1.Calc_WareHouseDesc,T1.Company,T1.EmpID,T1.ExtCost,T1.InvAdjReason,T1.JobNum2,T1.JobSeq2,T1.LotNum2,T1.OrderLine,T1.OrderNum,T1.PackLine,T1.PackNum,T1.PBInvNum,T1.PORelNum,T1.POUnitCost,T1.ProjProcessed,T1.SubUnitCost,T1.SysDate,T1.SysTime,T1.TranDocTypeID,T1.TranNum,T1.TranQty,T1.WareHouse2,T1.AdditionNum,T1.AsOfSeq,T1.AssemblySeq2,T1.BinNum,T1.BinNum2,T1.BinType,T1.Calc_Bin2Description,T1.Calc_BinDescription,T1.Calc_EntryPerson,T1.Calc_InvoiceDate,T1.Calc_ReasonDescription,T1.Calc_WareHouse2Desc,T1.Calc_Weight,T1.DisposalNum,T1.EntryPerson,T1.InvAdjSrc,T1.JobNum,T1.JobSeq,T1.LbrUnitCost,T1.LegalNumber,T1.LoanFlag,T1.LotNum,T1.MscNum,T1.MtlUnitCost,T1.OrderRelNum,T1.PartDescription,T1.PartNum,T1.Plant,T1.Plant2,T1.POLine,T1.POReceiptQty,T1.PurPoint,T1.TranDate,T1.TranReference,T1.TranType,T1.UM,T1.WareHouseCode,T1.RptLanguageID,T1.MtlBurUnitCost,T1.PCID
 FROM PartTran_" + Parameters!TableGuid.Value + " T1
 LEFT OUTER JOIN JobHead_" + Parameters!TableGuid.Value + " T3
 ON T1.Company = T3.Company AND T1.JobNum = T3.JobNum
 LEFT OUTER JOIN RcvDtl_" + Parameters!TableGuid.Value + " T4
 ON T1.Company = T4.Company AND T1.PartNum = T4.PartNum AND T1.LotNum = T4.LotNum
 LEFT OUTER JOIN Vendor_" + Parameters!TableGuid.Value + " T5
 ON T4.Company = T5.Company AND T4.VendorNum = T5.VendorNum
 LEFT OUTER JOIN Part_" + Parameters!TableGuid.Value + " T6
 ON T1.Company = T6.Company AND T1.PartNum = T6.PartNum
 ORDER BY T4.ReceiptDate"</CommandText>
Does anyone know what I’m doing wrong?
Error received when running the report:
Program Ice.Services.Lib.RunTask when executing task 4183923 raised an unexpected exception with the following message: RunTask:
Ice.Core.SsrsReporting.SsrsCaller.SsrsException: The SSRS server returned the status code 500 (InternalServerError) with the following error text:
An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset ‘PartTran’. —> System.Exception: For more information about this error navigate to the report server on the local server machine, or enable remote errors
at Ice.Core.SsrsReporting.SsrsCaller.SoapCaller.CallAsync[TContent,TResponse,TSoapHeader](String actionName, TContent content, TSoapHeader soapHeader) in C:_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\SoapCaller.cs:line 60
at Ice.Core.SsrsReporting.SsrsCaller.ReportExecutionService.Render(String format, String deviceInfo, String& extension, String& mimeType, String& encoding, Warning& warnings, String& streamIds) in C:_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\ReportExecutionService.cs:line 72
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 162
at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func1 timedAction) in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 0 at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReport(String ssrsRenderFormat, String printProgram, Boolean ignorePageSettings) in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 247 at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 418 at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 163 at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 34 at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func2 reportsRenderer, Action1 fillSysRptLstRow, Action2 processReport, Func3 filterTableAttachmentsFunc) in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 58 at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 359 at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93 at Ice.Core.RptTaskBase1.XMLClose() in C:_releases\ICE\ICE4.2.300.5\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 260
at Erp.Internal.IM.PrintMovement.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_releases\ERP\ERP11.2.300.0\Source\Server\Internal\IM\PrintMovement\PrintMovement.cs:line 255
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_releases\ICE\ICE4.2.300.5\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 68
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_releases\ICE\ICE4.2.300.5\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 64
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 450
Also would like to know the syntax for top 1 to be applied after the sort.
This might be a function I am not aware of - but what happens when you take the ** from before and after ORDER BY?
Whoops! The ** was meant to bold the specific line of code. My bad!
LEFT OUTER JOIN RcvDtl_" + Parameters!TableGuid.Value + " T3
 ON T1.Company = T2.Company AND T1.JobNum = T2.JobNum
There is something off in this join
You are correct! It needs to be linked on part and lot not job! Good catch! And that the T2 should definitely be T3…
