My PO report is strange, some of the sub-reports are somehow on a different path than the rest and was that ever fun to figure out why the solution wasn’t downloading! Is there a way to harmonize the paths so I can have everything in the same place?
When you make a subreport and insert it in a main report you have to give a path.
For some reason two of your subreports have a different path in them. Please go into the parent reports for the two sub reports that read \Epicor10Reports\Reports\CustomReports…
Change the subreport path to just be “POForm_POMiscCharges_UEl” and “POForm_PORelQty_UEI” respectively.
Thank you, this worked great and everything looks sorted out now.
Glad it is working.
