We have customized our Packing Slip and I have a very large packing slip that won’t print. This is the error Cannot read the next data row for the dataset ShipHeadShipDtl. —> System.Data.SqlClient.SqlException: Cannot create a row of size 20075 which is greater than the allowable maximum row size of 8060.
How do i figure out where this is coming from? I thought comments but there is only one small line of comments.
Ok, this means it cannot create the record. (It’s on the Reports tab).
Do you know which line it’s coming from? I’ve had Epicor Consultants help me design a Report Data Definition customization before and they unchecked all of the Exclude items. You may want to look there and see if you can eliminate any columns. Also try to print it with the standard report and see if that works.
I think I may have found it. Not sure. I printed the form with the base and got the GUID from there…and ran the custom report in SSRS. I got and error with invalid table name … maybe that is my issue just odd that some print and others won’t
If the base works, then you need to review the columns that aren’t excluded in the custom RDD. One column could push the record it’s trying to write past the 8K limit.
You would have to see what columns the DataSet on the report itself is using. Once you have that list it should be pretty easy to remove some of the noise.
If you copy the Base Dataset, and paste it into something like Notepad++, and do the same with your modified version - oftentimes after a few minutes of staring you see how the Base fields and the added fields and then any customizations are somewhat organized and you can kind of copy paste into a new version for the customization - but then you have backups of it, just in case. Oftentimes you can remove entire Datasets for some of the system “Call” ones and that sort of thing.
you might also have similar issue in that the Pack Slip:
I already have that personalization…I tuned that off a while ago after learning my lesson.
I removed a ton of un needed fields from theRDD. But do I need to remove them from the SSRS report too. I am just missing the connection…or disconnect. I wish there was a good video showing how to handle RDD and SSRS for EPICOR.
Basically if it’s in the RDL, then you’ll need it in the RDD. If you are sure you don’t use it for any calculations or grouping, then you can remove it from the RDL first. If the report still works then remove it from the RDD.
