Hello!
I am new to SSRS and Epicor - I have run through the available training. I need some help with adding a subreport to the AR Customer Statement. I am a Sage/Crystal Reports veteran.
In RDD - I attempted to add the table I needed for the report. This caused the report to run at a snails pace. I then created a subreport from a BAQ that has the required fields I need - they are for information only, no calculations (Job/Part Description/QuoteNum, etc) - I added the Subreport to the main report. Went back into Report Style and it fails on uploading the sub report to the modified form.
From what I understand - I have done the following in the following order:
- Save off the Standard - SSRS in Report Style (Created a Copy and renamed)
- Download SSRS Report
- Open the .rdl in Report Builder 3.0 - Make changes (without subreport first) Save
- Upload SSRS Report - Test in Customer Statements to make sure it is working
- Create subreport from BAQ - saved in Reports/CustomReports - this is where I think I’m doing something wrong…
- Open CustST .rdl in Report Builder - add subreport and link with param fields - Save
- In Report Style - I attempt to upload the modified report:
- I get an error that it can’t find the subreport… so I put the subreport in my working directory where I Downloaded the SSRS report and made the original modifications. It is not having any of that…
Any help is appreciated - I’m confused at this point. Do I need to Download the SSRS reports at the server level?
Thank you! EL
