I'm trying to modify the Bill of Lading form in Epicor 10 using the SSRS report builder. I modified the report data definitions, added the report style, edited the query and added the fields. The problem is that I am getting duplicate records; for example, a Bill of Lading that should have 3 lines has 18 (there are 6 identical records for each line.) I'm new to writing SSRS reports and I assume the issue is with the query but can't seem to pinpoint what it is.
="SELECT CAST(T1.BOLNum AS NVARCHAR) AS BOLNum
,T1.Carrier
,T1.CODAmount
,T1.Company
,T1.CommentText
,T1.FreightCharges
,T1.ShipDate
,T1.Plant
,T1.Calc_CustomerAddrList
,T1.Calc_PlantAddrList
,T1.Calc_ShipToAddrList
,T1.ProNumber , T1.Plant_Name
,T1.ToPlant_Name
,CAST(T2.BOLLine AS NVARCHAR) AS BOLLine
,CAST(T2.BOLNum AS NVARCHAR) AS BOLDetail_BOLNum
,T2.Company AS BOLDetail_Company
,CAST(T2.Packages AS NVARCHAR) AS Packages
,T2.Rate
,T2.Weight
,T2.WeightUOM
,T2.Calc_ClassDesc
,T2.Calc_PkgDesc
,T2.Calc_WeightDflt
,T2.Calc_WeightUomDflt
,T3.Company AS ShipHead_Company
,CAST(T3.BOLNum AS NVARCHAR) AS ShipHead_BOLNum
,CAST(T3.BOLLine AS NVARCHAR) AS ShipHead_BOLLine
,CAST(T4.ShipComment AS NVARCHAR) AS ShipComment , T3.PackNum AS ShipHead_PackNum ,T4.Company AS ShipDtl_Company ,T4.PackNum AS ShipDtl_PackNum ,T4.OrderNum ,T4.OurInventoryShipQty ,T4.OurJobShipQty ,T4.Packages as ShipDtl_Packages FROM BOLHead_" + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN BOLDetail_" + Parameters!TableGuid.Value + " T2
ON T1.Company = T2.Company AND T1.BOLNum = T2.BOLNum
LEFT OUTER JOIN ShipHead_" + Parameters!TableGuid.Value + " T3
ON T2.Company = T3.Company AND T2.BOLNum = T3.BOLNum AND T2.BOLLine = T3.BOLLine LEFT OUTER JOIN ShipDtl_" + Parameters!TableGuid.Value + " T4 ON T3.Company = T4.Company AND T3.PackNum = T4.PackNum"
Larry
Jose C Gomez
T: 904.469.1524 mobile
On Mon, Nov 9, 2015 at 4:07 PM, larry.jedik@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>I'm trying to modify the Bill of Lading form in Epicor 10 using the SSRS report builder. I modified the report data definitions, added the report style, edited the query and added the fields. The problem is that I am getting duplicate records; for example, a Bill of Lading that should have 3 lines has 18 (there are 6 identical records for each line.) I'm new to writing SSRS reports and I assume the issue is with the query but can't seem to pinpoint what it is.</span></p><p><span><br></span></p><p>="SELECT CAST(T1.BOLNum AS NVARCHAR) AS BOLNum</p><p><span style="white-space:pre-wrap;"> </span>,T1.Carrier</p><p><span style="white-space:pre-wrap;"> </span>,T1.CODAmount</p><p><span style="white-space:pre-wrap;"> </span>,T1.Company</p><p><span style="white-space:pre-wrap;"> </span>,T1.CommentText</p><p><span style="white-space:pre-wrap;"> </span>,T1.FreightCharges</p><p><span style="white-space:pre-wrap;"> </span>,T1.ShipDate</p><p><span style="white-space:pre-wrap;"> </span>,T1.Plant</p><p><span style="white-space:pre-wrap;"> </span>,T1.Calc_CustomerAddrList</p><p><span style="white-space:pre-wrap;"> </span>,T1.Calc_PlantAddrList</p><p><span style="white-space:pre-wrap;"> </span>,T1.Calc_ShipToAddrList</p><p><span style="white-space:pre-wrap;"> </span>,T1.ProNumber   , T1.Plant_Name</p><p><span style="white-space:pre-wrap;"> </span>,T1.ToPlant_Name</p><p><span style="white-space:pre-wrap;"> </span>,CAST(T2.BOLLine AS NVARCHAR) AS BOLLine</p><p><span style="white-space:pre-wrap;"> </span>,CAST(T2.BOLNum AS NVARCHAR) AS BOLDetail_BOLNum</p><p><span style="white-space:pre-wrap;"> </span>,T2.Company AS BOLDetail_Company</p><p><span style="white-space:pre-wrap;"> </span>,CAST(T2.Packages AS NVARCHAR) AS Packages</p><p><span style="white-space:pre-wrap;"> </span>,T2.Rate</p><p><span style="white-space:pre-wrap;"> </span>,T2.Weight</p><p><span style="white-space:pre-wrap;"> </span>,T2.WeightUOM</p><p><span style="white-space:pre-wrap;"> </span>,T2.Calc_ClassDesc</p><p><span style="white-space:pre-wrap;"> </span>,T2.Calc_PkgDesc</p><p><span style="white-space:pre-wrap;"> </span>,T2.Calc_WeightDflt</p><p><span style="white-space:pre-wrap;"> </span>,T2.Calc_WeightUomDflt</p><p>,T3.Company AS ShipHead_Company </p><p>,CAST(T3.BOLNum AS NVARCHAR) AS ShipHead_BOLNum</p><p>,CAST(T3.BOLLine AS NVARCHAR) AS ShipHead_BOLLine</p><p>,CAST(T4.ShipComment AS NVARCHAR) AS ShipComment , T3.PackNum AS ShipHead_PackNum ,T4.Company AS ShipDtl_Company ,T4.PackNum AS ShipDtl_PackNum ,T4.OrderNum ,T4.OurInventoryShipQty ,T4.OurJobShipQty ,T4.Packages as ShipDtl_Packages FROM BOLHead_" + Parameters!TableGuid.Value + " T1</p><p> LEFT OUTER JOIN BOLDetail_" + Parameters!TableGuid.Value + " T2</p><p> ON T1.Company = T2.Company AND T1.BOLNum = T2.BOLNum </p><p>LEFT OUTER JOIN ShipHead_" + Parameters!TableGuid.Value + " T3 </p><p><span></span></p><p> ON T2.Company = T3.Company AND T2.BOLNum = T3.BOLNum AND T2.BOLLine = T3.BOLLine LEFT OUTER JOIN ShipDtl_" + Parameters!TableGuid.Value + " T4  ON T3.Company = T4.Company AND T3.PackNum = T4.PackNum"</p><p><span><br></span></p><p><span>Thanks,</span></p><p><span>Larry</span></p><p><span><br></span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
