SSRS Custom Report Link
The Epicor version i am using is 10.1.400.12. Every time i try to use a SSRS Custom Report Link it seems to never really work. I choose the Option, then enter in my report path on the report server. Then click save. When i try to run the Report, I then get returned with an error that states: Invalid URI: The format of the URI could not be determined. If I close Menu Maintenance and go back in, it will have changed my link with Forward Slashes.
Is there something that I am missing? The only way i have been able to use SSRS reports within Epicor is by using a normal URL option in Menu Maintenance.
Chance
I have found that the only way I can make it work is to use the normal URL as well.
The way the SSRS Custom Report link is to work is that when you choose that menu option then the button will be available to look on the server to browse and select the report from SSRS but it does not seem to work and I read somewhere for Epicor 10 that it would be fixed in in later versions but it seems it has not been fixed for 10.1 as of yet.
Regards,
Kevin P Rosell
Cell: (281) 615-5248
Thanks for the reply.
I figured that this was the case. Ill keep this in mind going forward, and look out for when the update will roll out fixing this issue.
