Hi
Been looking at adding bar codes to reports. Ideally id like a coulpe of bar codes on our pack slip.
i have the DWBAR39.tff - ive installed the font on the server where report builder is installed and where ssrs reporting services is running. Ive installed the same on my pc where im running the report.
I have enabled bar codes in company config
Ive added a field to the report -with dwbar font selected
Hello, Carla. I am curious what does the ‘Value’ property for the desired barcode field look like? This to say, just to start with the basics, the field needs to have start and stop characters and not just the raw field data. For code39, asterisks. So, it will either need to be the Calculated BC field from the Dataset, or an Expression that you create.
Hm. Okay, well at least it appears to be a step closer. We’re not on premise so I am not certain if the Fonts need to be confirmed as being in place for the actual user account that your Epicor Windows Services is using, or what other configuration steps specifically are required, but it does seem to just be a configuration step.
no i have not- its a production server, i did restart ssrs
It is printing when outputting to word, or excel ive discovered, just not to pdf or when printing directly to printer
Thanks everyone- ive managed to get a word output to show the bar code, and it scans!
I also have a decimal field which i need bar coding- however the bar code is showing with a # - i dont think it likes converting a decimal …so i think its erroring
